If not a description at least a comment or reaction.
This the 1st linked Video:
At around 7mins 42 seconds he gets into In-Depth Oil Analysis Results.
NB the Boron ppm and the water ppm.
Both drop dramatically.
So while the use of Copper as a lubricant is interesting,
where did the Boron Esters go..???
"Where's aerohead":
After reading all you read in the other post you conclude that you are still clueless and have no idea where the Boron Esters and Water went!?
REALLY!????
Did all that really still fall into your: "I don't know whatTF's going on!? Best to stay away!" category?
Worse still: Conclude that aerohead is cleverer than you and does in fact know what's going on!??
Because he waved a smoke stick at a vehicle (but made no iterative changes, which is why manufacturers do it) and said stuff like 'Vena Contracta' emphatically..?
Ever asked him to please explain Vena Contracta or any of his vast list of acronyms?
Because if he in fact does; he can...
