Old 01-16-2023, 12:23 PM   #31 (permalink)
Yea I'm upset about there not being easily published specs on tires.
The Following User Says Thank You to liquidshadowfox For This Useful Post:
aerohead (01-16-2023)
Old 01-16-2023, 12:28 PM   #32 (permalink)
wheel covers
I've no idea what the cost was, but on an episode of 'Rick's Restorations', a local Las Vegas, Nevada sign company created high density foam tooling using AUTO-CAD-CAM, used to vacuum-form heated polycarbonate sheet material over, creating a clear structure, much like poly skylights are formed.
It would be interesting to know what Lexan covers like this would fetch.
The Mercedes' EQXX concept wheels are completely 'sealed' like this would be.
Old 01-16-2023, 01:28 PM   #33 (permalink)
...used to vacuum-form heated polycarbonate sheet material over...
Clamp it under a perfect 19[-21]" circle and inflate it with compressed air. Trim to fit.
Old 01-16-2023, 05:09 PM   #34 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
At 70mph most of your battery energy is going to pushing around air. There are two ways to help reduce that effect.
  1. Drive slower.
  2. Change the shape of the vehicle like this guy: https://www.aerocivic.com/
Well, I guess there's a third option. Sell the crossover and get something more aerodynamic like a sedan or an Aptera.
Tires might help some. But will it be enough?
Old 01-16-2023, 05:17 PM   #35 (permalink)
Not gonna sell, love this car and yes I'll drive slower to compensate but when I do get my hands on those hancook ion tires and the wheel covers ill do some testing and report if there are any range gains. Do you think a front air dam would help? Not sure considering the bottom of the car appears to already be pretty smooth.
Old 01-16-2023, 05:29 PM   #36 (permalink)
A front air dam might help slightly. Or it could hinder slightly. It mainly helps vehicles without a smooth underside.
Although the 65+ Efficiendy Mods list puts a front air dam at a moderate increase in better mileage, so that's encouraging.
https://ecomodder.com/forum/fuel-eco...ifications.php
Old 01-16-2023, 05:36 PM   #37 (permalink)
90 day: 29.78 mpg (US)
New tires generally get worse economy. You want really worn out ones if you want good economy. That's a separate discussion from buying efficient ones to begin with.
I doubt an air dam would help since EVs in particular are designed with smooth airflow in mind. My guess is it would make things slightly worse.
Isaac Zachary (01-16-2023)
Old 01-16-2023, 05:41 PM   #38 (permalink)
The rear of any vehicle is where most of the aerodynamic drag can be helped. People like boxy rear ends, so manufactures don't go all out aerodynamic on the rear. But if you did it yourself you could get a major improvement in range, much more than with eco tires and front air dam combined.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
freebeard (01-16-2023)
Old 01-16-2023, 07:03 PM   #39 (permalink)
As said, air dams are a band-aid. At the very least provide a central notch to provide a high speed jet that will pull air from behind the wheels.
A splitter won't impede the approach angle (as much) and provides 'free' downforce.
Old 01-16-2023, 07:12 PM   #40 (permalink)
Any examples of this notch?
