Old 03-11-2010, 02:07 PM   #11 (permalink)
hi
I built me a mpguino, perfectdar I work a little problem
not indicate liters / h when the speed is zero mean you are on the spot
is a problem or it must indicate?
sometimes when the engine is cold and the consumption is greater than 1 liter ralanty show and when consumption decreases and reaches around 0.6 liters indicate when 0 when 0.6 seconds and then nothing.
Is it resistant to 100 kohm too high and reduce the signal so that it mpguino not notice?
Thanks for your help
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
MPGuino and ScanGauge question americasfuture2k Instrumentation 0 11-19-2008 01:56 PM
Question about EOCing a manual McTimson Hypermiling / EcoDriver's Ed 7 10-24-2008 06:34 PM
Chysler patent raises technical question about injector accuracy monroe74 OpenGauge / MPGuino FE computer 11 09-12-2008 09:21 PM
MPGuino Question jmassengill OpenGauge / MPGuino FE computer 2 06-15-2008 01:16 PM
