Old 10-27-2009, 07:03 AM   #11 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Thanks, cfg83. No, I wasn't the first. I was inspired by Xringer. I'm not sure what basjoos used.
Now I need to get that belly paneled in...
-Terry
Old 10-27-2009, 07:21 AM   #12 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
My gutters have been on for over a year now (painted w/black Krylon as well). No problems from the few times I've scrapped them.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 10-27-2009, 08:11 AM   #13 (permalink)
Hi folks,
Can I ask what is the intended aerodynamic function of these side skirts?
Personally, it feels a bit counterintuitive -- I would think that you want to have air "escape" out from under the car; and not to trap it under the car. And none of the ultra-low Cd cars that I am aware of have anything like this.
Old 10-27-2009, 08:50 AM   #14 (permalink)
chuckm's Avatar
The Loremo has side skirts. Some high performance vehicles extend their bodywork down lower than the lowest point on the suspension.
I think the idea is that air wake generated by the tires does not propagate and further disturb the air flow underneath the car.
Old 10-28-2009, 10:18 PM   #15 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
NeilBlanchard -
Hi folks,
My (ever so flawed?) thinking is that I am separating the "clean airstream" from the "bad airstream", but I don't really know. With this mod I think I should create a "snow-plow" air dam to minimize the amount of air flowing under the car. If nothing else, in tandem with an air dam, I think this could be a form of "virtual lowering".
I did some flow simulation YouTubes and found something interesting. The imaging is a top view and is problematic, because none of the "objects" actually touch the ground, they only interfere with the air stream. I was trying to simulate the engine, transmission, suspension, and exhaust piping :
If the above is showing a valid result, then the rear ( non-moving!!! - ) tires seem to have less turbulence associated with them.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Rokeby (10-29-2009)
Old 10-29-2009, 06:03 AM   #16 (permalink)
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
Rain gutter material also makes a nice front air dam...
ID:	4636   Click image for larger version
Old 10-29-2009, 12:29 PM   #17 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I thought about trying side skirts but attaching isn't near as friendly as that Saturn. I'd have to fab something up, and would probably use more lawn edging. I got a bunch of it from spring cleanup piles earlier this year, some of it still brand new.
Winter daily driver, parked most days right now
Summer daily driver
Old 10-29-2009, 01:58 PM   #18 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
instarx -
Oh yeah, I remember yours. Fantastic work because it's so OEM-ish.
CarloSW2
Old 03-31-2012, 06:49 PM   #19 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
Based on this comment from aerohead :
Originally Posted by cfg83 View Post
ps2fixer -
I see those side skirts all the time. I think that if it's proven then they'll do it. The Aeroflex is also a model for our side skirts, aka taper in at the front.
CarloSW2
NASA's research demonstrated an 8.7% drag reduction @ zero crosswind,and 19% drag reduction under a 6 mph wind @ 6-degrees yaw.
I modified my side skirts to taper-in at the front *and* taper-out at the back. It was super-easy to do because there are only 3 wing nuts holding it up. I left the center wing nut the same and drilled new holes in the rain gutter on each end. The new holes were offset 1/2" from the original holes. That leads to this look from below :
And from the side :
I don't think the taper-out at the back matters because the side skirt and rear front mudflap are already sticking out. It's probably a better compromise.
I doubt it will make a measurable difference, but I like the idea of copying the "trucker side skirt" model.
CarloSW2
Old 03-31-2012, 07:05 PM   #20 (permalink)
FFE - '17 Ford Focus Electric
Thanks for bumping up the thread. Ingenious idea.
Effectiveness of side skirts? fanamingo Aerodynamics 14 04-07-2022 01:57 PM
Temporary side skirts? atomicradish Aerodynamics 9 07-02-2011 06:52 PM
Finally Got Side Skirts Big Dave Aerodynamics 16 07-01-2009 10:03 PM
Side skirts? hamorhead Aerodynamics 6 09-16-2008 06:52 PM
Side skirts fastening tasdrouille Aerodynamics 9 08-01-2008 01:24 PM
