Old 09-25-2008, 11:05 PM   #1 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Calibration Math
I have been trying to calibrate guino, and have found a simple math solution.
Odometer=20 Guino=20.14
20.14-20=.14
.14/20=.007
.007x100=0.7% difference
If guino is high subtract 0.7% from vss pulse entry, if guino is low add.
Could be used for gallons as well.
Correct me if wrong.
Old 09-25-2008, 11:17 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Here's what I had in the wiki:
Mpguino calibration - EcoModder
EDIT: THIS IS WRONG, THE WIKI IS BEING UPDATED!!!
"A. navigate to the "VSS Pulses/Mile" screen (hint, left and right buttons will "tab" to the next field"). Take that value, divide it by the number of miles the guino said you traveled, then multiply by the number of miles on the odo. Adjust the value to this new value and hit OK."
In your example, lets say you had 8208 in the "VSS Pulses/Mile" screen.
the new "VSS Pulses/Mile" value would be (8208/20.14)*20.00 or 8151.
you want to increase "VSS Pulses/Mile" if the guino reading is high, so that it counts more pulses before registering a mile.
Old 09-25-2008, 11:35 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
I might want to follow my own advice
It should be (8208/20.00)*20.14 or 8265. Lemme redo the wiki page...
Old 09-25-2008, 11:35 PM   #4 (permalink)
Addicted
bbjsw10's Avatar
In your example you said if guino is high to add, you subtracted.
Wouldn't you want to do this math if guino is high.
(8208/20)*20.14=8265
Or
.14/20=.007
.007x100=.7%
8208+.7%=8265 same as above.
Edit:caught mistake same time as you. So I think the easy way would be your math just make sure to divide vss by smaller of two readings. Correct?
Old 09-25-2008, 11:51 PM   #5 (permalink)
Addicted
bbjsw10's Avatar
On another note do these adjustments automatically reflect without resetting tank or current. That way showing the distance right then and there without having to drive a couple hundred miles to see the difference. And as a way to check math, like "212 on odo. and 212 on guino=sweet)
Old 09-25-2008, 11:52 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
It's just this:
newVSSPulsesPerMile=vsspulsesPerMile*guinomiles/odomiles
edit it would reflect on the current tank screen, except mine hung after writing the eprom It might just be a onetime thing though (added a parameter to 7.3).
Old 09-25-2008, 11:59 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ok, wiki updated. need to youtube it or something.
Old 09-26-2008, 12:09 AM   #8 (permalink)
Addicted
bbjsw10's Avatar
Went out and tried it 14.9 on odo. and guino. Thanks!!!!
Couldn't sleep good til I tried it out. My rate is 8440 as of right now, going to log more miles to see if it changes at all.
ScanGaugeII Throttle Cut Off and MPG Calibration ballegre Instrumentation 9 07-18-2008 02:46 PM
Math behind MPG offroad1994 EcoModding Central 14 06-30-2008 09:31 AM
SuperMID calibration - need advice Cd EcoModding Central 3 06-26-2008 12:57 AM
Can people not do math anymore? adam728 The Lounge 30 06-09-2008 01:45 PM
SuperMID calibration methods ? / overinflation valve stem failure Cd EcoModding Central 8 03-30-2008 09:15 PM
