Old 01-03-2023, 03:55 PM   #21 (permalink)
So this picture is inaccurate:
Both 2D representations are incomplete. Without the inward rolling vortexii coming off the B-pillar to feed the engine air.
Note also 1500CFM of heated air ejected as a jet under the rear bumper.
aerohead (01-03-2023)
Old 01-03-2023, 04:09 PM   #22 (permalink)
inaccurate?
Completely!
The 1500cfm would be a contingent upon the bi-metallic, thermostatically-controlled cooling fan inlet bell-mouth position.
freebeard (01-03-2023)
Old 01-04-2023, 10:12 AM   #23 (permalink)
Afaik, only the early single ports < 50 hp had the bell mouth variable intake. All my stuff had the exit flappers which usually ended up stuck closed, but carry on
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
aerohead (01-05-2023), freebeard (01-04-2023)
