Old 11-16-2011, 12:20 AM   #1 (permalink)
Ace - '99 Ford Ranger XL
Re - Tired
Hi, I'm looking at putting wheel discs on my Ford Ranger. It currently has 15" Rims with 225/70/15 Tires. The tires are almost bald so I was considering replacing them with LRR tires.
I would also like to install Wheel Disc too. I currently have aluminum wheels and would like to get the snap on discs but they only work on steel rims. I found several sets on craigslist in 14", 15" and 16". Does anyone know which diameter would be best for fuel economy. Also, is it possible to run a narrower LRR tire and if so what size would I need.
Any guidance would be much appreciated.
Thanks.
Old 11-16-2011, 12:48 AM   #2 (permalink)
You probably have the ultimate low RR tires, in the best size, on there right now!
Hotrod_ace (11-16-2011)
Old 11-16-2011, 11:57 AM   #3 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Continental]Continental CrossContact LX 215-15, 27.7" dia.; 225-15, 27.4" dia.; 215-17
General Grabber HTS 225-15, 27.4" dia.; 215-16, 27.9" dia.
The Following User Says Thank You to Patrick For This Useful Post:
