Ready...set...go!
Here is a sketchup model of my car, on your mark, get set, MOD!!!!!
I will post pictures of the completed mod, but I need your help! Help me design some aero mods for this van. Thanks, Phreakuency |
Start off with a grill block and then try some rear wheel skirts.?.
If you have a roof rack, delete it. (unless it's really needed). |
I'll go ahead and do that, also I will take before and after pictures, and also hopefully more people post.
Inflate tire to max rating if you feel safe doing so.
Make sure the engine is up to date on maintenance (tune-up, fuel and air filters, etc) Grill block Underbelly pan Rear wheel skirts Weight reduction (spare, jack, rear seat, etc) Be sure to check out the 100+ driving tips HERE |
So I took off the antennae and the bars going across the roof rack. I am wary about taking off the roof rack because there are holes that I don't know how I will cover.
Remove the rack, and if you do not want to use silicon, then get some vinyl sticker tape in the color that most closely matches the van, heck no one will see it on the roof.
Just drop the screws that hold the rack on now back into the holes.
Losing the Antenna doesn't really do anything for you. Plus now you don't have a radio!
for a while, I agreed. It could be 1% of your total drag, IF you were already driving a super aerodynamic car.. But, if your ride is an SUV, Van or PU..?. I'm gonna go with less than 0.1% of total drag. |
