Old 01-05-2024, 05:09 PM   #1 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Chery .16 CD drag car
https://cnevpost.com/2023/11/02/cher...nd-resistance/
very interesting chinese concept design for low drag.
rear box cavity fins and '' shocker'' flat wheel covers
more info and photos - https://www.greencarreports.com/news...-efficiency-cd
The Following 3 Users Say Thank You to Phase For This Useful Post:
aerohead (01-06-2024), Joggernot (01-08-2024), Vekke (01-08-2024)
Old 01-05-2024, 11:03 PM   #2 (permalink)
The Corvette Mako Shark looks more like a shark than this looks like a Tuna Fish.
Beats out the Mercedes boxfish concept for Cd, though.
Old 01-06-2024, 02:44 AM   #3 (permalink)
Phase's Avatar
heres another low drag chinese car. i like this shape more
The Following User Says Thank You to Phase For This Useful Post:
Old 01-06-2024, 11:45 AM   #4 (permalink)
' Cd 0.168 '
* Better than the Dodge-Ghia 'Dart' concept, Cd 0.17,1956.
* Matches the 2006, Daihatsu UFE-III concept.
* A little dirtier than the 2012 Illuminati Motor Works 'Seven-I ' @ Cd 0.165.
* And a little dirtier than GM's 1999 Precept, @ Cd 0.163.
* Trailing behind Li-ion Motors WAVE-II, 2012, Cd 0.16
* Edison-2 VLC, Cd 0.16
* Challenger-I, Mickey Thompson, 1959.
She might get a 'fail' on A-pillar rain-gutters, mirror size, and mirror rain-shedding, which might bring her down to the 2022 Think Flight Subaru Impreza, or Lightyear Zero.
Glad they did it!
Old 01-06-2024, 11:48 AM   #5 (permalink)
' GAC '
Have you seen the 2019, GAC ENO. 146, Cd 0.146 ?
Old 01-06-2024, 01:20 PM   #6 (permalink)
Fiat Turbina Prototype 1954. Fiat’s experimental gas-turbine car, the Turbina held the record for the most aerodynamic car (0.14 Cd) for thirty years
carsthatnevermadeitetc.tumblr.com/post/100694483802/fiat-turbina-prototype-1954-fiats-experimental
aerohead (01-08-2024)
Old 01-06-2024, 03:51 PM   #7 (permalink)
Phase's Avatar
Yes I like that one. It’s pretty low to the ground and there’s no wheel arch gap. So I’m curious to how stiff the suspension is and how that handles bumps and drops. Literally no room for the wheels to move. But cool design
I’m curious to why the chery has a lower CD than the second post I showed with the long boat tail tear drop car
Old 01-08-2024, 03:06 AM   #8 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Those active arch gap fillers make a big difference. Do they work in real life is a another question. Similar could be made pretty easily in own workshop.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
Old 01-08-2024, 11:33 AM   #9 (permalink)
' Cd 0.14 '
*I attempted an energy balance for the Turbina, and nothing I could do would reconcile the discrepancy between the reported values and physics.
*The car was tested only as a 1/5th-scale model in the wind tunnel.
* From Hucho's 2nd-edition, we find that the 1/5th-scale Schlorwagen model drag coefficient was 69% lower than it's actual 1:1-scale results ( Cd 0.11 vs Cd 0.186 ).
* Had the Turbina demonstrated a similar discrepancy, we might be looking at something in the neighborhood of Cd 0.2367, instead of 0.14.
* Even when discounted to the higher Cd, terminal velocity power absorption is only 135-horsepower at an assumed, drag-limited top-speed, compared to an available 288-hp at the traction interface.
* I located five cars with fineness-ratios similar to Turbina, which produced an aggregate average Cd 0.1661, at within 0.4% fineness-ratio agreement.
* We're cautioned to view 'early' wind tunnel quanta with a bit of skepticism. This certainly qualifies.
freebeard (01-08-2024), Piotrsko (01-09-2024)
Old 01-08-2024, 11:45 AM   #10 (permalink)
'why'
I'm going to wait and see if technical images ( blueprints ) of the cars show up online.
There are at least nine metrics I like to be in possession of, in order to facilitate an evaluation of any specific vehicle.
The GAC ENO.146 used the 1981 Volkswagen-Flow Body upper body contour, which appears to be remarkably more conservative than that of the newer GAC TIME.
This is the most important feature on an automobile, and determines whether there's a 'favorable', or 'adverse' pressure gradient.
It's easy to get this wrong, and end up snatching defeat from the jaws of victory.
