Old 04-13-2008, 10:07 AM   #1 (permalink)
fabrio.'s Avatar
tigra AERO - '96 opel tigra
rear diffuser
Hi boys
I am going to make the rear diffuser on my car, but serching in all my documentations, I do not understand what is the ideal rear diffuser angle in order to drag reduction.
I suppose, that this angle, he is conseguence of same car measure like the lengh of total body and the lengh of rear diffuser, but also the ground clearance.
Do you have some indications to tell to me?
thanks
Old 04-13-2008, 03:14 PM   #2 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Don't go with more than 10 degrees and you'll be fine.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-13-2008, 03:38 PM   #3 (permalink)
fabrio.'s Avatar
thankyou tasdrouolle, tonigth I have installed the rear diffuser.
Small spaces do no permit me to change the actual inclination that is aboud 2°, but afterday, I will go to measure him.
Do you think that this small 2° inclination is bond or bad ?
Old 04-13-2008, 05:51 PM   #4 (permalink)
2 degrees is ok. A couple degrees more would be better, but that would mean cutting your bumper so it's a no go. You just don't want your diffuser to be too steep else the flow will not stay attached to it.
By looking at the brackets you made to support the diffuser I'd say it's more than 2 degrees for sure, but you measure and tell us.
Old 04-13-2008, 06:14 PM   #5 (permalink)
fabrio.'s Avatar
yes, afterday, I measure him correctly, and tell you.
For increase the actual angle, I must change the actual rear diffuser with other material more slim of actual.
The limit from spare wheel compartment!
With slim element, I can retrive few centimeters for gain angle.
I think that you have look my last work about the rear diffuser.
Ok, for now, I thank you
Old 04-15-2008, 02:40 PM   #6 (permalink)
DMC - '99 Honda Civic DX
I used common sense..make sure the air flows and doesn't get stuck anywhere...
diffuser taken off
diffuser on car
Old 04-15-2008, 03:46 PM   #7 (permalink)
Originally Posted by Compaq888 View Post
diffuser taken off
It looks very smooth. What kind of material is that?
Old 04-15-2008, 05:56 PM   #8 (permalink)
honestly I have no idea...I just went to the home depot roofing section and they had a lot of these sheets...
Old 04-16-2008, 02:21 AM   #9 (permalink)
Cool thanks, I'll check it out.
Old 04-16-2008, 12:12 PM   #10 (permalink)
fabrio.'s Avatar
good clear work Compass, thankyou for your prensence
I think (but), that in your rear diffuser, the sepaation point of flow, isnt' fixed because, the rear end of pannel is too up curved
This one, cause not predictable turbolence (i think)
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
Video: tuft testing (rear) 1993 Ford Mustang notchback MetroMPG Aerodynamics 12 02-05-2011 09:40 AM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 12:01 PM
Rear window fairing (roof extension) apgrok1 Aerodynamics 14 03-12-2008 12:33 AM
