Old 09-08-2016, 05:26 PM   #1 (permalink)
Considering a low, flexible air dam
After 15 great years, my 2000 Honda Insight was totalled. Not that bad an impact - an older car is worth next-to-nothing so it's easy to get totalled.
I got a 2007 Prius, and it behaves differently, but that's for another thread.
Got several project for my Prius, including an air dam to improve the underside aerodynamics.
I'd like the air dam to come 2-3 inches of the pavement, and think it might be possible if the last few inches are flexible plastic that could give so the road does not chew it up fast. Anyone try this?
The Following User Says Thank You to Chuck. For This Useful Post:
aerohead (09-08-2016)
Old 09-08-2016, 06:06 PM   #2 (permalink)
anyone?
MetroMPG reminded us that the Crisis Fighter Pinto of CAR and DRIVER,1974, had a very low airdam and it helped with their MPG.
Also,graduate engineer Feysal Ahmed's Masters Thesis research showed a drag reduction for a pickup with a 3" clearance airdam,although he recommended it only for racing applications because of the demands of driveway ramp clearance 'n such.
Some members have used rubber belting for low airdams and it seems pretty indestructable.
Give it a go and keep a good logbook to see if she 'shows' on the computer or at the pump.
Old 09-08-2016, 06:29 PM   #3 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I was thinking about putting one that low on Ron Burgundy myself before an armadillo took out part of Turtle's belly pan.
I don't know of any material that will give you the aero benefits you're looking for and also survive an armadillo hit with it hanging that low. But if you find it, I might still do one myself!
Here in central Florida we also have lots of gopher turtles, racoons, possums, the occasional cow in the road, etc . . . . lots of stuff to tear off all my hard work
The Following User Says Thank You to cowmeat For This Useful Post:
aerohead (09-10-2016)
Old 09-11-2016, 01:26 PM   #4 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
I put a rubber conveyor belt air dam on my 2005 Toyota Tacoma. I use it offroad a lot and have drug it repeatedly without issue. See the link to by build thread below, note that I changed it a couple times throughout the build.
I love it for the handling increase.
http://ecomodder.com/forum/showthrea...tml#post453541
The Following User Says Thank You to aardvarcus For This Useful Post:
aerohead (10-01-2016)
Old 09-11-2016, 04:53 PM   #5 (permalink)
Anyone try this?
I haven't, but I've got 3 1/2" clearance to the tow hook and maybe 5" to the front valance. I'd drop it another 1 1/2" but there are 3 bump strips between the street and my carport.
The best one I've seen I can't find using site search, maybe someone else will recognize the description. It was a Metro/Civic-like vehicle with a conveyor-belt airdam down to 2-3", like you say, in front of the tires but was notched up maybe 2" in the center.
I think this would do two things. The extra clearance delays high-centering on gravel drives, etc.; and the center section didn't have the curvature of the ends to resist deforming so it's gets relieved for less pressure.
For some idea of the pressure involved look at this air dam:
Look how thick the aluminum plate is, and the number of fasteners to hold it on the car. These Beetles don't run much above freeway speeds.
You might want to use something like spring steel fingers or something on the upper backside.
BamZipPow (09-28-2016)
Old 09-28-2016, 03:22 PM   #6 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I used 3/8" ripstop conveyor belt for my air dam.
The stuff is a bear to fabricate and not at all cheap, but it is flat indestructible. I've had it on my truck for over five years and and it is in good shape. A little rubber conditioner and it looks like new.
After much experimentation I found that the right height for the air dam is about 7" above grade in front of the wheels and 9" above grade in the center. this height keeps it out of parking curbs.
I tried my air dam as low as 3" above grade but at that height it dragged the ground every time I hit the brakes. No major damage (just ground the botto a little, but it annoyed the hell out of me.
I'd recommend the stuff.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following 3 Users Say Thank You to Big Dave For This Useful Post:
aerohead (10-01-2016), BamZipPow (09-28-2016), MPGeo (09-28-2016)
Old 09-28-2016, 04:24 PM   #7 (permalink)
Thanks for suggesting the central notch.
If it was easy to fabricate, it wouldn't be as indestructible. What did you use to cut the ends and the notch?
Old 09-28-2016, 05:48 PM   #8 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
If you want super cheap, lawn edging from one of the big box home centers.
If you want wookie-tested/wookie-tough, conveyor belting like Big Dave said. It sounds like a specialty product but baler belting is essentially the same thing, and you can get that at Tractor Supply in widths up to 10" by 15 feet. $100 out the door, not bad considering what you're getting.
The Following 2 Users Say Thank You to elhigh For This Useful Post:
aerohead (10-01-2016), MPGeo (09-28-2016)
Old 09-29-2016, 09:16 AM   #9 (permalink)
aardvarcus's Avatar
I cut mine with a sharp utility knife following a ruler/straightedge. It cuts pretty good but you need a sharp blade. I got a 7" by 15' roll at TSC, it was less than $100, probably about $50 or so. I also ordered another piece of conveyor belt off ebay (which I haven't used yet), they have every size imaginable and their prices are better then TSC.
The Following 3 Users Say Thank You to aardvarcus For This Useful Post:
aerohead (10-01-2016), elhigh (09-30-2016), freebeard (09-29-2016)
Old 10-01-2016, 01:03 PM   #10 (permalink)
airdam & belting
This photo is from a Master's Thesis done by a US NAVY officer,sent to me by 'bondo'.He also used the conveyor belting,and as you can see,went very 'low' with it.
