Old 07-10-2009, 09:12 PM   #1 (permalink)
Metallover's Avatar
Focus - '08 Ford Focus SE
90 day: 32.26 mpg (US)
Recycling heat energy
Well, When gas burns in an ICE engine, 40% is wasted as heat and 30% is used to cool the engine. Only about a quarter of the energy in the gas is converted to mechanical energy.
Do you think there would be some pretty big gains if someone came up with an efficient way to recycle the heat? Is there already a way?
Old 07-10-2009, 11:01 PM   #2 (permalink)
Hi,
Sure, heat can be used to produce electricity, so you could replace the alternator.
But it would be much better to convert more of the fuel's energy to mechanical motion in the first place -- and produce less waste heat. The cam driven Revetec engine is ~2X as efficient (39.5%) as the typical piston engine, since the mechanical leverage of the cams can be designed -- crankshaft and connecting rod engines are locked into sinusoidal motion, which wastes a lot of energy.
Also, the weight of the vehicle is a huge drain -- check out Amory Lovins on the specifics:
Amory Lovins on winning the oil endgame | Video on TED.com
swede (05-06-2010)
Old 07-10-2009, 11:12 PM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
thermo electric generators can turn about 3-5% of the waste heat from a source like your exhaust in to electricity at a cost of about $2,000-3,000 for a single car to elimenate the alternator.
Old 07-11-2009, 12:13 AM   #4 (permalink)
Hyundai Accent - '01 Hyundai Accent
90 day: 38.4 mpg (US)
Gixer - '97 Suzuki GSXR600
90 day: 43.12 mpg (US)
Turbochargers have been used for a long time to capture waste energy from the exhaust.
Old 07-11-2009, 08:50 AM   #5 (permalink)
BMW came up with a 'turbosteamer' engine that used the heat from the exhaust and coolant to provide propulsion power. I don't think it ever went anywhere though.
Old 07-11-2009, 09:44 AM   #6 (permalink)
What about inject water into the exhaust after the cat and spin a turbine with the mixture of exhaust gas and steam?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 08-06-2009, 11:19 PM   #7 (permalink)
Metallover's Avatar
If 30% of the energy in gasoline is wasted keeping the engine cool, can something like a "mesh" hood help mpg? Something made out of a material that allowed heat to rise up through it yet keep most of the passing air from creating drag would be perfect.
Imagine your car without a hood on. All the heat from the engine could rise out of the opening.
You could even go as far as putting heatsinks on the engine.
Anyone want to try this out?
Old 08-07-2009, 01:19 AM   #8 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Nope, because it won't work. The fuel used to keep your engine cool is primarily designed to keep it from knocking, which can't be helped by external cooling. You can help it with water injection, though.
A tight enough mesh probably wouldn't affect aero too much, but it would let the engine overcool between trips, meaning that you'd probably spend more time in open loop operation, which is less efficient overall, as a general rule.
Old 08-10-2009, 11:57 AM   #9 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Engine bay vents in the bodywork (hoods/fenders) with coolant temp. controlled shut off valves. The valves would open at the same time the grill blocks open. Hope they don't stick closed like a thermostat.
Don
Old 05-04-2010, 12:32 PM   #10 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Terawatts of heat are lost to the environment every year due to the inefficiency of heat energy, but startups like Lawrence Berkeley National Lab’s spin-out Alphabet Energy are looking to create materials that convert waste heat into usable electricity. This morning Alphabet Energy announced that it’s raised a small seed round of $1 million from venture investors Claremont Creek Ventures and the CalCEF Clean Energy Angel Fund.
One-year-old Alphabet Energy develops “thermoelectrics” for waste heat recovery — semiconductor materials that generate electricity when you make one side hot and the other side cold. The startup says it can create them at a cost 50 times cheaper than existing materials, and at around $1 per watt for industries such as heavy manufacturing, automotive, aerospace and power generation (see our list of 7 Startups Building Green Car Tech for a Pre-Electric World).
The company says its first product will be on the market within 2-3 years and it has already raised $320,000 in Small Business Innovation Research grants from the U.S. Army and Air Force and the Department of Energy. This latest seed funding will go towards producing commercial prototypes of devices that can be used in existing semiconductor infrastructure, says Alphabet Energy.
Claremont Creek Ventures has backed other efficiency plays like smart thermostat software maker EcoFactor, and efficient lighting company Adura Technologies.
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
New 1/2 house A/C time dremd Saving@Home 16 06-17-2010 10:11 PM
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 10:15 PM
