09-11-2009, 06:10 PM
#11 (permalink)
I think it might help, mainly as wind fences on the sides. I think that is what lunarhighway is saying in post #9, point 1. I think wind fences could be beneficial on a lot things, particularly pickup trucks. I have done no testing to confirm or disprove this, just a hunch.
09-11-2009, 06:53 PM
#12 (permalink)
Dartmouth 2010
As others have said, I think if you do something to prevent the flow from detaching at the back glass you might make use of the boundary layer effect.
However, I suggest you go ahead and try it! It would look cool, anyway
09-11-2009, 09:10 PM
#13 (permalink)
Yet another reminder is many of us experience strong x-winds on a regular basis. Once I calculated it and I see 11-22 degree yaws on a regular basis. I suspect fins in the yawed condition would be more a liability than an asset. A 14 mph x-wind can cut fe 13% at 55 mph.
09-11-2009, 10:10 PM
#14 (permalink)
Good point Frank. I think I'll stick to some vortex generators to achieve a similar affect.
09-11-2009, 11:06 PM
#15 (permalink)
vortex generators
my car has a built-in vortex generator, it's called the *** end.
09-11-2009, 11:07 PM
#16 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
I was waiting for that response...
09-15-2009, 05:47 PM
#17 (permalink)
notch-back
You're graphics are top-notch! I like where you're trying to go but my brain has hit two glitches.I suspect that from the driver position,unless the vanes are splayed out to respect line-of-sight through the rear view mirror,you'll develop tremendous blind-spots at each side of the rear windshield.---------- The other thing that may enter the picture,is much surface area friction and shedding vortices behind each vane due to dead spots close to and directly behind each vane.--------- Something that worked on my CRX,was to keep the end plates and blend them into the C-pillars,then,at the "top" of the vanes,construct a single flat spoiler shelf which runs horizontally right up to the backlite.The air captured below the shelf will be below the Kamm profile,and above it,you'll have a single attached vortex which the outer free stream will bounce off,reattaching at the tail of the shelf.--------------- There's a lot less skin friction,it's simpler to construct,rear visibility is maintained accept at the extreme sides and it's lighter and should do the cleanup just as well.
