EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   Removing decals? (https://ecomodder.com/forum/showthread.php/removing-decals-9163.html)
Daox 07-09-2009 01:20 PM
Removing decals?
As most have seen, I just picked up a Prius. On the back, the dealer of course had to slap his decal on. I don't like it and want it off. Chalk it up as a weight reduction if you want to. :p I just don't like it. So, what is the best way to remove a decal?
Piwoslaw 07-09-2009 03:56 PM
Warm it with a hair dryer, or let it warm up in the sun (with the careful help of mirrors or lenses) if you don't want to use electricity. Then try to 'floss' it with fishing line. I'm thinking of doing the same with a few decals I have, and that is the answer I got when asking around.
Shawn D. 07-09-2009 07:55 PM
"Flossing" works on foam-adhered badges, but it won't work well on a decal.
If a hairdryer doesn't do the trick, get some General Purpose Adhesive Cleaner #051135-08984 from an auto body supply shop -- it will dissolve the glue without harming the paint. It's a great solvent for working around the car, so you'll find other uses for it as well.
dremd 07-09-2009 08:39 PM
Heat + plastic paint scraper and maybe some solvent.
!!!!!NOT SOLVENT + HEAT!!!!!!!
Johnny Mullet 07-09-2009 09:45 PM
Heat is the trick and then a good fingernail will work it off without damage. After it's removed, buff it.
Terrh 07-10-2009 12:12 AM
if it's one of those thick plastic ones, just peel it off with fishing line or something, then use goo gone and a cloth to remove the remaining stuff.
if it's a normal decal, you can buy a rubber wheel that goes on a drill and will be amazingly effective at removing it. Goo gone for the remainder.
Some polish and wax after and it'll probably disappear.
RandomFact314 07-10-2009 12:46 AM
I JUST posted a post like yesterday, of me removing all the badges on my car, I sprayed it with goo gone, let it sit for a few seconds and got some thread and flossed all of them off, really easy... http://ecomodder.com/forum/showthrea...tyle-9154.html was my post
Peter7307 07-10-2009 01:30 AM
Eucalyptus oil is another eco friendly oil which happens to be great for removing glue residue from decals etc.
Cheers , Pete.
SVOboy 07-10-2009 07:05 AM
Sand-blaster! I hear the rough surface will make the paint like a golf ball and therefore more aerodynamical!
elhigh 07-10-2009 10:37 AM
Bad Yankee! No Chowder!
