View Poll Results: Has MMO added to your gas helped you?
Yes, I used it, and it worked. 1 50.00%
I used it, but no, it did not work. 1 50.00%
Voters: 2. You may not vote on this poll
Old 03-22-2015, 03:49 PM   #1 (permalink)
I am trying to read up on Marvel Mystery Oil, on here and elsewhere, and so far I am seeing many people saying it worked, some saying it did not provide noticeable benefit, and some insisting that it is "snake oil," without having any idea how to prove that it does or does not work.
Thank you very much! Please enjoy your day!
Old 03-22-2015, 03:57 PM   #2 (permalink)
beastie - '89 toyota hilux dolphin motorhome
Puggie - '98 Peugeot 406 Lx
subscribed
Old 03-22-2015, 04:46 PM   #3 (permalink)
Dark Egg - '12 VW Touraeg
I have used it as a detergent in motors before and it works. Most noticeably to free stuck valves in small lawnmowers. I would not say it is snake oil, but a light machine oil with additives, probably no snakes. Similar to ATF but they each have different additives and the ATF is not meant to be burned like MMO can be.
Where are you talking about using it, in the crankcase or in the fuel?
Old 03-23-2015, 12:29 AM   #4 (permalink)
The product is composed of 74 percent mineral oil, 25 percent stoddard solvent, and 1 percent lard.
Marvel Mystery Oil - Wikipedia, the free encyclopedia
It seems like many Honda drivers on here add it to their gas to help enable their lean-burn habits.
Old 03-23-2015, 02:08 AM   #5 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Seems like after reading the 3 ingredients in MMO it would be super easy and cheap to just mix your own.
1998 LX with a full HX swap + VX transaxle.
Old 03-23-2015, 03:14 AM   #6 (permalink)
Marvel Mystery Oil, 1gal - Walmart.com
Sixteen dollars per gallon at Walmart.
By the way, it is Xistday again. Boo!
Old 03-23-2015, 08:20 AM   #7 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Never used it, rxp seemed to help my mileage but nothing drastic
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
Old 03-23-2015, 08:30 AM   #8 (permalink)
KFM
KFM's Avatar
Terminator - '00 Honda Insight Base
Gen-1 Insights
90 day: 72.78 mpg (US)
High Voltage - '12 Chevrolet Volt
Team Volt
90 day: 108.44 mpg (US)
Hmmm... pretty sure I have a bottle sitting on my shelf from my old Civic. I'll have to give it a try in the Insight next tank.
Old 03-23-2015, 03:05 PM   #9 (permalink)
Apparently it's a pretty good cylinder/fuel system cleaner, but I don't know that it would help on an already clean engine? I put it into my MR2 before, couldn't tell the difference but it made me feel good so it was worth it haha. Snake oil ftw.
