Old 01-30-2015, 10:24 PM   #171 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Do you just need to wait a few seconds after switching the key to on to let the caps build up, before you move it to start? Or is that the issue? Would that prevent the voltage sag?
Old 01-30-2015, 10:31 PM   #172 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
OK, so I've been watching my voltage lately and it turns out my issue was simply too much EOC. The voltage dip is gone but my MPG has taken a big hit. Solar panel will be here next week so that should solve all.
The voltage still takes a dip to below 12V when bump starting though which I find a bit surprising.
Old 01-31-2015, 01:42 AM   #173 (permalink)
Enki's Avatar
Think of capacitors like compressed air tanks for electricity. There's no waiting to use their contents, and as they are used, their pressure (voltage) drops linearly. It would be better to start the vehicle quickly so they don't drain too much.
If you mean bank of 350 farad caps, I don't really find that surprising. In series, six of them would total 58.33 farads of capacitance, giving you an amperage dump of 233.32 amps (from 14 to 10 volts drop). That isn't much.
The stumble could be from any number of things, like there not being enough voltage to excite the alternator immediately. I'd recommend testing with a larger bank of 650s (108.3 farad effective, 433.2 amps capacitance), or adding a second bank of 350s (which should halve voltage drop).
Old 01-31-2015, 06:41 AM   #174 (permalink)
Team Turbocharged!
Pickups
It is indeed this. The alt is ECU controlled and doesn't fire for about 5 seconds after a bump (or key) start, what was confusing me is the big drop from firing injectors and plugs. The 100W solar panel should fix all my issues though.
Old 02-05-2015, 08:58 AM   #175 (permalink)
Team Turbocharged!
Pickups
So my problems are still not over. I fitted the solar panel in a big hurry after work yesterday and this morning got in the car reading 14.2V, started it, and big stumble (the kind I normally get if it's been sitting for a few days).
Could my supercap wires be too small? The biggest I had was 8GA.
Old 02-05-2015, 11:29 AM   #176 (permalink)
Enki's Avatar
I'm not really sure what your goal was with the solar panel, but they aren't exactly going to flash fill the caps during a start.
Old 02-05-2015, 07:14 PM   #177 (permalink)
Team Turbocharged!
Pickups
Since the problem only exists after being parked overnight, and gets worse if left longer, I was hoping increasing the initial voltage would work.
I'm wondering if the 8GA wires are too small for the cap to supply enough amps to crank the engine, but big enough to suck current away from the coils just after cranking.
Old 02-05-2015, 08:38 PM   #178 (permalink)
Enki's Avatar
It could just be that cold starts take a bunch more power than warm ones (morning vs afternoon cold starts)...?
Old 02-05-2015, 09:27 PM   #179 (permalink)
90 day: 29.78 mpg (US)
8 AWG is certainly large enough, assuming your leads aren't extremely long.
Your issue is strange because I have never had caps cause worse performance. I suspect something else is going on. My motorcycle, Camry, and TSX can all start off the caps and run without issue. I've measured voltage sag as low as 6.6v while starting the TSX on caps alone, and it runs just fine after starting.
11v should be plenty for the car to run without having ignition issues. Does the car start and run properly when you put a known good battery in? I'd take your Jeep battery and see if the problem is still there.
... in other news, the 3400 farad caps are on the way. It will be about a month before I get the time to test them in my Dodge/Cummins truck, sans battery. I bought zener diodes and white LEDs and will test to see which makes for a better balance circuit.
Old 02-06-2015, 06:34 AM   #180 (permalink)
Team Turbocharged!
Pickups
It's a hot summer here so morning starts aren't really that cold.
The car and battery are new and had no issues prior to fitting the caps. This morning it started perfectly though so fingers crossed the ECU has 'learned' something.
I did first use the caps on the Jeep and also got a slight stumble (the battery IS weak on that one), and the caps couldn't start my 875cc Fiat, barely got a turn of the flywheel.
Beginning to suspect it's the caps themselves that are faulty, but then they seem to bench charge fine.
