Old 06-25-2013, 10:24 PM   #1 (permalink)
05-hilux-3d - '05 toyota hilux workmate
90 day: 27.65 mpg (US)
tow-patrol - '99 nissan patrol st
90 day: 16.88 mpg (US)
fuel use of large mining equipment
as part of my job i sometimes end up with the lovely task of helping out refilling mining equipment i thought i would post fuel use of some of these huge bits of kit as you guys love numbers
cat 785 dumptruck v12 engine burns through 80-100 liters an hour depending on length of run and load type
komatsu ex3000 v16 cummins engines burns through 150-180 liters an hour
komatsu 785 hd v12 engine smaller than a cat 785 burns through 50-80 liters an hour depending on load and run length
cat d10r dozer this one has a huge fuel use span of between 50-120 liters an hour depending on wheather being used to rip or push dirt ripping uses the most matters how much the operator has a nap to
these may seem like huge amounts but the amount of dirt these huge machines move its very good!!
The Following 3 Users Say Thank You to deisel-lux For This Useful Post:
aerohead (09-09-2024), Cd (06-26-2013), oil pan 4 (09-09-2024)
Old 09-09-2024, 10:43 AM   #2 (permalink)
' mining equipment '
For open pit mining in the USA, the actual 'mining' equipment operates on electricity.
