Old 10-28-2008, 10:54 AM   #11 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Originally Posted by TestDrive View Post
Take a look at the figure in Step 1 of this article.
The image in the first post of this forum thread may also be useful.
So the wear I'm measuring on two of my tires is that of under inflation - just like this image, just not to the degree.
I might just bring it in for a 4 wheel alignment.
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 10-28-2008, 11:59 AM   #12 (permalink)
MechE
Okay, so I found the problem... And it was an easy fix....
It was me :X
I remeasured, and noticed a chamfer on inside the tread valley (I guess to reduce stress concentration).... My caliper was resting on the chamfer, not completely seated in the valley... Measured from the center of the valley (not on the chamfer) - everything is nominal...
Side to Center to Side - everything is within a couple thousandths I'm good to go for another 25K miles, at high pressure and even wear
Sorry for the bad call Thanks for the help
Old 10-28-2008, 02:13 PM   #13 (permalink)
Turbo gas guzzler
grocery getter - '03 Mitsu Evolution
90 day: 17.55 mpg (US)
In the immortal words of Homer Simpson "DOH!!!"
Old 10-28-2008, 03:56 PM   #14 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
I'm guessing that by chamfer you mean the 2/32" high wear indicators molded into most tires.
(I believe US DOT requires them in passenger car tires.)
Example 1
from Tires, Page 3 of 4
Example 2
from Checking Your Tires for Wear - For Dummies
FWIW - I prefer a standard tread depth gage ($2-$3 from any auto parts store).
The compact design makes it easy to use in the wheel wells of most passenger cars.
Old 10-28-2008, 06:01 PM   #15 (permalink)
"Boo Hoo to you everyone that said I'd wear out my centers at these pressures "
Well it looks like those pressures will work out for you. I do know, however, that I've had tires wear just like the "overinflation" pic in post 11. Vehicle was almost always very lightly loaded, and at max sidewall psi. Are tires different now? Were the rims too narrow for that tire? I dunno. But overinflation wear down the middle is not a myth.
Old 10-28-2008, 06:56 PM   #16 (permalink)
Yep, no myth. I've had tires wear like that to. I'd guess that old style, bias ply tires were more prone to that type of wear?
Old 10-28-2008, 11:13 PM   #17 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
i get digional wear heal toe.??
can u expain what u found?
Old 10-29-2008, 12:22 AM   #18 (permalink)
They are, but these were radials.
Old 10-29-2008, 08:34 AM   #19 (permalink)
Diagonal wear is most likely a bearing or race.
Old 10-29-2008, 09:38 AM   #20 (permalink)
is diagonal like feathered? cause it is both front and even, it has done this for years.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
LR Horrible Tire Wear Noel Off-Topic Tech 3 06-03-2011 06:47 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 07:14 PM
