rpm monitoring
I've read alot of the shift recommendation on shifting. I've always done the 2-2.5(3 when necessary) accelaration between shifts. I saw a few people mentioning 1500 rpm but my question is this my cars engine blocks start jumping and making a lot of not friendly noises if i dont keep the rpms above 2k? Is there something im suppose to do the motor mounts to enable this or is this common fuel effeciency for trucks vs car?
Some cars work better in different rpm ranges.
If you car if bucking and making unfriendly noises at 1,500 rpm then maybe you just need to keep yours a bit higher. Best practice is to go as low as possible without your car bogging down or throwing a fit. |
You may be asking too much of it at that rpm. Back off the throttle a bit and it'll likely smooth out nicely.
as hypermiling goes, demanding and bogging...
find out your cars max oil pressure at oem rpm.. 2850 rpm is in my own for example to max the oil pump. This helps ensure relief valves do not petrify, and of course gives everything a max shot of a thing called lubrication. :rolleyes: the inliners REALLY need this maximum shot. |
Aspire as in Ford aspire? Thats thats really strange considering my festiva would lug down to 1000 pretty well. The Aspire IS a couple hundred pounds extra but they made up for it with shorter gearing. You should be able to cruise 25 in 5th gear easily. You could always try swapping the sohc 1.6 out of a 323 for a little extra oomph down low, its a direct bolt in.
The B8 it a good motor too, just slightly more involved than a B6 swap. Best power per effort swap for our cars though. Shouldnt be too much of a hit to the MPGs either. B8's have the best low end torque of any of the B series I think. And its not too much power to have to swap trannies either. Look out for a protege, should be easier than finding a 323 with a B8.
Though after swapping a B6T and G25MR in my festiva I feel like I could do anything now lol. Its worth it though, and I should be able to manage 40mpg pretty easily. Ive gotten 38.9 and 38.4 my last two tanks, and I still have plenty of room for improvement. Im running without the o2 sensor right now because I have the infamous exhaust manifold crack thats drawing in air over the o2 causing it to run rich (32 mpg). Im also running the stock festiva exhaust which is killing my low end torque with the turbo. |
