Old 09-25-2009, 02:52 AM   #1 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
'01 GMC Sierra 1500 is worthless
I needed a break from my Honda so I started trying to up the FE in my GMC Sierra 1500.
This thing is a fuel hungry monster. I have tried all the easy mods and have had no luck
I can drive this thing like a "Bat out of Hell" or like a grandma going to church and it gets the exact same mileage.
Anyone have any suggestions for this beast???
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-25-2009, 11:20 AM   #2 (permalink)
Dart Lite - '76 Dodge Dart Dart Lite
90 day: 18.34 mpg (US)
Beater..with a Heater - '94 Isuzu Rodeo LS
90 day: 16.19 mpg (US)
The engine is a derivitive of the Corvette and Camaro engine. They choked it down for use in the trucks.
I would look to some traditional "power" modifications as means to allow it to breathe. Air intake, exhaust, headers. There is software, LS1 Edit, among others that will allow you to modify the code. Most use it to custom tune for higher horsepower applications, but it will also allow you to build your own MPG tune.
Current MPG driver:
1994 Isuzu Rodeo - Beater with a Heater...
The Following User Says Thank You to Backtobasics For This Useful Post:
Domman56 (01-05-2010)
Old 09-25-2009, 12:00 PM   #3 (permalink)
Sell it.
Old 09-25-2009, 12:05 PM   #4 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
I'd go with the remap and breathing. allow the engine to run naturally but just try and not be tempted by all that power!!!!!!!!!
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 09-25-2009, 03:02 PM   #5 (permalink)
Maybe modified gear ratios to go with the engine mods? 3.08 rear end was available on those with the V6.
Old 09-25-2009, 03:11 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Taller gearing in the back perhaps?
Old 09-25-2009, 04:04 PM   #7 (permalink)
darcane's Avatar
Which "easy mods" have you tried with no results?
I've got basically the same truck ('03 Silverado W/T Extended cab, 4.8L with 3.73 gears) and have been considering a few eco-mods. I would be interested in knowing what other have found not to work so that I might avoid wasting my time on them.
I've read reports of 1-2mpg gains by getting the ECM tuned, and these guys seem to be the best deal: Black Bear Performance :: Custom Tuning Solutions for 96 and newer GM Vehicles I'll probably get this done in a few months.
Mike
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 09-25-2009, 04:31 PM   #8 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Mike
I haven't done a whole lot, just the low $$ mods.
Canopy
Tire pressure increase to 50psi
Driving techniques
Driving with out A/C with windows up
premium fuel
The next thing I'm going to try is a non-ethanol fuel.
Old 09-25-2009, 05:02 PM   #9 (permalink)
darcane's Avatar
The number on thing I've done is removing the ladder rack that was on it when I bought it.
Is yours 2wd or 4wd? My best so far is a little over 19mpg. Mine is a 2wd and stock except the canopy and I've upped it to 45psi in the tires.
-Mike
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 09-25-2009, 05:32 PM   #10 (permalink)
Originally Posted by pgfpro View Post
premium fuel
I question the need for premium?
Higher octane rating actually burns slower then lower octane. HP applications need the octane higher to resist pre-ignition. I doubt your truck actually needs it.
Electric fan?
Current MPG driver:
