Old 10-27-2014, 03:25 PM   #1 (permalink)
Rembrant's Avatar
Swapping in taller 5th gear? (09 VW "City" Golf 2.0L 8v SOHC gas)
Hi Folks,
I'm looking into a 5th gear swap that would drop my highway speed engine RPM's by approximately 400.
My car normally runs right on 3000 RPM @ 100km/hr when in 5th gear. This gear swap would essentially drop my RPM's to 2600 for the same 5th gear speed.
I know you guys are old hats with all this stuff, so can anybody speculate as to how much benefit this would actually be...in MPG terms? 1 MPG? 2? None?
Any of the BTDT guys have any thoughts on the matter?
Thanks,
Rem
~You can walk a mile in another man's shoes, but then you're a mile away and you have his shoes~
Old 10-27-2014, 03:29 PM   #2 (permalink)
What car do you drive? What speed do you drive? What kind of mileage do you currently get with the car?
Need moar info!
The Following User Says Thank You to Daox For This Useful Post:
mcrews (10-27-2014)
Old 10-27-2014, 03:52 PM   #3 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
some cars are easier than others. S-series saturns and VW golfs can be done with the tranny in the car and ~$20 and a trip to the boneyard. Others might also be easy. It is a no-brainer for those with a 5th gear cover that you can get to in the car (and at the boneyard). Otherwise consider a tranny swap.
Old 10-27-2014, 04:06 PM   #4 (permalink)
The wiki says 7-20% increase depending on the vehicle.
Regear for lower cruising RPM - EcoModder
Old 10-27-2014, 06:00 PM   #5 (permalink)
Rembrant's Avatar
Need moar info!
Originally Posted by P-hack View Post
some cars are easier than others. S-series saturns and VW golfs can be done with the tranny in the car...
Yup...09 VW Golf "City" Model, which is just a re-released version of the 2004 and earlier MK4. 2.0L 8v SOHC 4 cylinder.
My current best is 35mpg (usg) @ 60mph all hwy with cruise control.
Not sure what to expect, but I'm usually blindly optimistic.
Rem
Old 10-27-2014, 06:17 PM   #6 (permalink)
P-hack's Avatar
depends on your current ratio (5th and final). here is an article on the hows: 5th gear swap modification- lower gearing on a VW 5 speed transmission | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
There are gains to be had for sure, but will need more technique than cruise control to take full advantage of them.
Also the gains are manifest when combined with aerodynamic mods.
Old 10-27-2014, 06:24 PM   #7 (permalink)
Rembrant's Avatar
According to the code on my trans:
1st: 3.778
2nd: 2.118
3rd: 1.360
4th: 1.029
5th: 0.837
R&P: 4.235
I simply want to swap the 5th out for a TDI 5th (7.44-7.56) or pick up Euro 5th kit @ .717 ratio.
I'm not going to get into swapping the R&P...I'm not that eager...but a 5th set swap is just an afternoon in the garage. Might give it a whirl.
Old 10-27-2014, 07:02 PM   #8 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.43 mpg (US)
My question is... WHY?
Why would VW stick anything approaching a 4+ ratio in the "diff". I get that acceleration on the highway excuse, but 3k RPM's on the highway? At the speed limit no less.
Brainless.
Old 10-27-2014, 07:10 PM   #9 (permalink)
Rembrant's Avatar
Brainless.
I know, right?
This is my issue and why I want it to settle down @ hwy speeds.
A coworker of mine has the identical car and @ 75mph on the hwy, he gets only 22-23mpg compared to my 32-34 when driving @ 60mph.
In any case, I just want to get it down below 3000 RPM @ 60mph.
The 5th gear swap seems to be the easiest and most cost effective way to do it.
Maybe I'll miss the power it has in 5th now, but if the increase in MPG is decent, I don't care about the power.
Old 10-27-2014, 08:09 PM   #10 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
I'm considering swapping in a transmission with a 3.73 final, a 3.545 1st, and a .725 5th if I can find it. The importance of this? I'd go from a 4.33 final, 3.166 1st, and a .815 5th to previously mentioned transmission. Since 4th is .969 on both, the first transmission's 4th gear is as tall as the second's 5th gear so I wouldn't lose any highway acceleration capabilities that bad.
I live in socal so I have to go up some steep grades on the freeway if I drive it more than 30 miles either way.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
