Old 03-23-2014, 09:27 PM   #1 (permalink)
EOC kill switch for a carb'ed RX7
I've been coasting a bit in this 83 Rx7 with the engine on. I'm thinking on killing the engine and coasting . I see lots of stuff for fuel injected cars. Not much for Carbed. Whats the best way for me to kill the engine , coast and bump start?. SC
Old 03-24-2014, 07:21 AM   #2 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
You might need to design your own custom solution to stopping the fuel instantly in the carburator.
Old 03-24-2014, 10:47 AM   #3 (permalink)
As long as there is air flow through the carb and fuel in the fuel bowl then air and fuel will continue to be mixed.
You are going to have to EOC.
Old 03-24-2014, 05:47 PM   #4 (permalink)
Hmm, if the engine is off ,no vacuum, no gas. I,m thinking cutting power to distributor. Would kill it. Sc
Old 03-24-2014, 06:07 PM   #5 (permalink)
It's possible there is an idle circuit cut off solenoid which was used in the last days of carbs to keep the engine from running when you turned it off. I know they used them in Nissans, not so sure about the Wankel engine. It would probably show on a parts breakdown for the fuel system, possibly on the emissions systems.
regards
Mech
Old 03-24-2014, 09:03 PM   #6 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Yes the idle cut off solenoid, keeps cars from running on, dieseling. Cars when unleaded first came out would not turn off.
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
Cobb (03-25-2014)
