Old 10-12-2009, 07:19 PM   #1 (permalink)
EcoDriver
BlueCivic - '97 Honda Civic LX
90 day: 33.3 mpg (US)
Fuel injector puller
I fought with pulling a bad injector for about an hour twisting and pulling - actually just tearing up fingers.
Small channel locks were the key!
You just have to be careful not to snap off the top.
Just wanted to share that tip.
Old 10-13-2009, 12:39 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Push it down with your thumb as tightly as you can muster, spray in some WD40 or even just use some gas (not as effective), then work it with your fingers up and down in the direction that you'd be pulling it out.
Often, I'll get a cut pigtail from the same type of injector and use that as ballast to pull it from more than one angle.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
