Old 05-02-2010, 10:25 AM   #1 (permalink)
Driving the TurboWeasel
Honda ATF return line?
Which is the return line on most Honda automatics? I have a choice of 2 on my fiancee's 09 Fit AT. There's a big long line on the driver's side running over the transmission that gets really hot. I'm guessing this is the feed line. There's also a much shorter line that stays pretty cool to the left of the big long line. I'm guessing this is the return line.
2012 Chevrolet Cruze Eco 6MT
Old 05-02-2010, 11:07 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The cooler of the two lines after a "spirited" drive will be the return.
You can also check by starting the car in neutral with one line disconnected... the return line won't spurt fluid out under pressure, although some may still come out.
If there are two different sized lines, I believe the smaller one tends to be the return.
Old 05-02-2010, 06:25 PM   #3 (permalink)
texanidiot25's Avatar
Formula - '96 Firebird Formula/Trans-Am
90 day: 19.31 mpg (US)
You guessed correctly.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 05-03-2010, 11:40 PM   #4 (permalink)
Thanks!
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
fuel return line on a lebaron or ram 1500 v8? dcb EcoModding Central 2 08-27-2009 06:26 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Honda Begins Use of Class 8 Hybrid Truck Q1000 Hybrids 0 03-11-2009 07:55 PM
