Old 09-08-2010, 03:07 PM   #1 (permalink)
The PRC.
SG2 - Negative MPG ?
Had a busy day today and had some time limits which meant I had to use higher speeds than normal. So I took advantage of fuel cut-off and higher speeds to get my instant SG2 MPG to read as high as possible (e.g. 5645mpg) whilst coasting at 80+ - I have a 6sp so why not use it
The SG2 and on-board averages are getting much closer - despite not being below 75 much on the way back I got 56.7 on the SG2 and 57.2 on the on-board.
Anyhoo one thing I did notice was on some occasions the SG2 actually read negative instant MPG on a couple of occasions. It was when things were 'complicated' - e.g. in traffic, around the transition either to or from a pulse vs a glide - so I can't pinpoint exactly why.
Anyone else seen this ?
Old 09-08-2010, 03:28 PM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Damn you're good!!!
Old 09-08-2010, 05:48 PM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Piwoslaw View Post
Damn you're good!!!
No, he's getting too good, and tailgating me
Old 09-08-2010, 08:50 PM   #4 (permalink)
Negative MPG doesn't even make sense.
Going negative miles in a gallon?
Old 09-09-2010, 12:06 AM   #5 (permalink)
The PRC.
Well, if MPG = Miles travelled / fuel used
then if Miles or fuel is negative then the result could be negative.
I was going forwards at the time so I suppose the engine was putting fuel back into the tank from the exhaust.
*(goes off to find patent lawyer...)
Old 09-09-2010, 12:11 AM   #6 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Are you sure you sere sitting in the front seat? I know some like to drive from the back seat...
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-09-2010, 12:33 AM   #7 (permalink)
The PRC.
The roundy thing was just in front of me, if that helps ?
free OBD2 software with MPG calc whitewiz Instrumentation 11 12-10-2014 10:53 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
SGII first observations! gone-ot Success Stories 10 04-02-2010 01:26 AM
SG2 or new Kiwi MPG gabrannon Instrumentation 15 07-12-2009 08:07 AM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
