04-05-2011, 05:29 PM
Do more with less
What kind of FE instrumentation for Pre-OBD2 Diesel
Any suggestions on fuel economy gauge for my 1986 VW turbo diesel?
If you haven't noticed from my car choice; it has to be cheap.
I have thought about using a linear variable resistor and wiring it to an electric meter. Since the fuel is used directly by the position of the foot feed (and the rpm) I might have a relative way of improving my mileage.
– Noah Webster, 1787
04-05-2011, 05:38 PM
What about some kind of crank trigger and magnetic pickup device to give you an "rpm" so to speak. It may not give a total and accurate RPM, but I would think it could be hooked to a gauge of some sort to give you feedback, even if the gauge says you are turning 8000 rpm at idle and 10,000 rpm at speed?
Current MPG driver:
1994 Isuzu Rodeo - Beater with a Heater...
04-06-2011, 12:12 AM
Smeghead
w terminal on your alternator gives a pulsed signal for RPM.
Boost guage.
EGT guage (peak EGT is best performance mixture) Lean (less throttle) of that gives better MPG.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
02-05-2012, 08:57 PM
sorry, i cannt help you, and i want to know th answer.
03-05-2012, 10:34 AM
I am up against this problem as well. My truck has no instrumentation in line on the fuel. I'd need to have two flow devices, on for fuel in and one for return. It is cost prohibitive for me.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
03-05-2012, 10:50 AM
Do more with less
Yeah really not much to do unless we want to develop a fuel usage gauge where we could see GPH and then work backward to get MPG.
What I have done is to pull the start lever out. It seems to give better fuel mileage.
03-05-2012, 01:15 PM
home of the odd vehicles
I am in the same boat on My 89/82 6.2 diesel, without GPH, no way to get instant FE.
I think something needs to exist for GPH.
03-05-2012, 01:29 PM
Smeghead
vern if you are pulling the lever out for and it is making a mileage difference you may think about adjusting the injector timing.
my understanding of the VW injection system is that while pressure to the injector is over x value a spring allows the injector to open.
in the pump if a pressure measuring device "knew" when the injector was opening and closing by sensing the pressure in the line (vw uses a variable stroke injector pump) longer stroke means higher flow rate and longer duration with the injector open. that information could be fed to an MPguino.
What we would have then is frequency and duration which is handled well by MPGuino, unfortunately duration and volume of fuel is probably not linear, but that could likely be solved with software.
03-06-2012, 04:33 AM
#9 (permalink)
I just thought that diesel injestion timing may be "measured" by a microphone attached to the injector. Since it'a a fully mechanical unit it should be pretty easy with an oscilloscope to find the point and timing for actual injection. As I remember diesel (old type) injectors are set up for constant fuel pressure, so what's changing is time. If you could actually measure the time of injection you can actually find an amount of injected fuel. Combining that with some kind of vehicle speed sensor will give you a full MPG. I think it can be done pretty easily. I could try to do that but don't have access to any old diesel engine and what worst I don't have oscilloscope to find characteristic points of the measured sound.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
03-09-2012, 04:45 PM
#10 (permalink)
Mechanical diesels normally use a lumosity probe adaptor that goes in a glow plug hole to detect combustion. The lumosity adaptors are typically used drive a standard gasoline timing light.
I have one and its so nice, not having to guess at your timing.
