Old 06-12-2008, 07:20 AM   #11 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Originally Posted by ttoyoda View Post
I must disagree. A wing with a flat bottom may generate lift from the bottom, but that is only if it has a non-horizontal angle of attack.
The length of the air path is not relevant, even though that is the way many people explain it. Lift is caused by curvature of streamlines. In any curving streamline, the air pressure is lower on the inside of the curvature, and higher on the outside of the curvature.
This paper explains the idea, and it is permissible to glaze over the math.
http://ocw.mit.edu/NR/rdonlyres/Aero...0/4liftgen.pdf
Wow. That's why I'm not an engineer.
Still, I would think that if having a very flat bottom on a car would have any seriously adverse effects outside of salt flat speeds, someone here would have experienced it.
Old 06-12-2008, 08:05 AM   #12 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
At the speeds we hypermilers are going, you shouldn't have to worry about any serious problems with lift even IF it did generate any at all. If anything, it will only slightly reduce the weight of the vehicle on the tires and give you less RR
aero, belly pan, undertray
Autospeed article: adding a chin undertray to a 1st gen Prius MetroMPG Aerodynamics 20 03-18-2014 05:31 PM
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 05:13 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 08:49 AM
Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 12:27 PM
aluminum undertray advice wanted lunarhighway Aerodynamics 27 06-18-2008 04:29 PM
