Old 01-12-2009, 08:11 PM   #11 (permalink)
Pushrod - '02 Chevrolet Cavalier
the ONLY way I can get the 450mile per 12 gallon full tank (37.5mpg) is by slip streaming all highway travel. the higher RPM while the engine decides to warm up is frustrating me to no end.
Idle your car hot, then pull the idle air control wiring harness from the valve. It will stay in that position. I unplugged mine two years ago. The only real side effect is that the engine idles erratically with the A/C on a cold engine.
Scion xA aero mods NeilBlanchard Aerodynamics 521 04-20-2015 10:34 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 08:49 AM
SG2 worth it for a xa? hyperhall Instrumentation 20 10-04-2008 09:55 PM
Scion undertray. whokilledthejams Aerodynamics 11 06-12-2008 08:05 AM
Hybrid Electric Scion xB trikkonceptz Hybrids 5 06-02-2008 05:14 PM
