Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 03-11-2013, 02:16 PM   #11 (permalink)
Aerodynamics rules
Viturro's Avatar
the only good thing on that engine, is that when you compress the air on the cyl. the air dissipates the heat on that cyl, then you have ''fresh'' air on the other cyl... nah...
Other ''GREAT'' thing about that engine! more pistons! oohh... awesome
must be fake.
Old 03-11-2013, 03:33 PM   #12 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
I can't see how adding twice the components per cylinder is a good thing? If the other piston fired also you would still have a power stroke every crank rotation. It looks like they took an early W design and did some clever animation.
Project Avalon: E bike build
Old 03-11-2013, 04:44 PM   #13 (permalink)
more pistons!
As I see it, the design replaces a 4-stroke 4-cylinder with a 2-stroke 2-cylinder (with two 'helper' cylinders). The component count really doesn't change, just the manifolding.
I suspect there may be issues with the fixed crankshaft offset having a non-linear effect at varying rotational speeds.
