Old 05-17-2015, 01:19 PM   #11 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
My ? Is what % of trucks using the *runaway ramp for emergency use only * on Donner Pass 40 miles down hill have the new wheelcovers i was told by a 45ydriver the thing ceeping whee covers off the road is end cost its cheeper to burn fule than replace tires because your drivers didnt check air pressure with the covers in place . As well reduced mpg from running low air
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 05-17-2015, 01:53 PM   #12 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Originally Posted by Baltothewolf View Post
A lot of trucks in California rock the side skirts/moon disks/trailer tails. I talked to quite a few truckers over the course of me working in security at a truck gate. The gains are actually quite good from reports. One fellow I remember talking to said at 55mph he gained 3mpg increase, from 9mpg to 12mpg. It may not seem like much, but when you do close to 50k miles a year, the savings are enormous!
9 MPG = 11.1x Gallons per hundred miles
12 MPG = 8.5 Gallons per hundred miles
Per thousand:
9 MPG = 111.x Gallons per 1k
12 MPG = 85 Gallons per 1k
And ten thousand:
9 = 1,11x Gallons per 10k
12 = 850 Gallons per 10k
Yep.
Old 05-17-2015, 09:21 PM   #13 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
what? didn't understand your statement.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
bikeprof (05-18-2015)
Old 05-17-2015, 11:54 PM   #14 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
My question is has their ben an increase of trucks loosing thier breaks from extra heat buld up running covers . The rest was a reason why we dont see more covers on the road over the last 3 decades
Former
87' Hyundai Excel
Old 05-18-2015, 03:12 PM   #15 (permalink)
This should be adequate for brake cooling:
Originally Posted by mooneyesusa
MOON WHEEL DISCS can be made up to 46" in diameter. Don't see your size listed? Contact us for custom applications.
http://www.mooneyesusa.com/MOON-Disc-Screw-on-p/md11-sc.htm
Their order form pop-up lists 10-18".
That example shown with the open center probably clamps to the rim. I'll see if I can find the reference.
Edit: I came up dry on Ecomodder, but there's the very thing:
http://www.ryderfleetproducts.com/deflecktors-22582512410s/fuel-saving-wheel-cover-for-steel-wheels-22.5-p-dfl-22582512410s
It turn out they're made from (possibly vinyl-coated) fabric.
If your taking the Donner pass, it would be easy enough to remove them at the summit. Next time you're there, check out the restroom at the 'Safety Stop', it's the most awesome one I've ever seen.
Old 05-18-2015, 03:53 PM   #16 (permalink)
Wannabe hyper..., miler !
bikeprof's Avatar
White Variant - '96 Volkswagen Passat TDI ~ GLS- 4 Cyl
Minivan - '96 Chrysler handicap IMS built LXI
Insight - '10 Honda Insight EX
Hmmm, big trucks loosing "their" brakes is not the trucks fault.
The operator behind the wheel is THE fault behind trucks "loosing" the brakes!
Been driving since 1977(large trucks), and have seen quite a few instances where trucks were in "runoff's" and that is a good feeling but at the same time, amount of dollars that someone had to pay for the extraction is/was what makes an impact to me...
1. Run off ramps ARE designed for the occasional reason of mechanical disparity
2. Run off ramps, there ALSO for the more often ERROR in driver/operator F__K UP, exits installed there hoping these will save lives(and they do!)
3. Brake pad/shoe mal-adjustment happens to be top three use of run off exits
4. SPEED, actually... OVERSPEED is also top three(hmmm, sure!?!?), hahahaha
But wheel covers, I would debate this.
More an excuse and blame to accuse others of driver error; UNLESS the wheel covers cover BOTH sides of wheel assembly(in n out), covering drum, not letting any air thru to cool stuff off. (these don't exist though...)
Old 05-18-2015, 08:18 PM   #17 (permalink)
Experienced UAW Mechanic
Cover either single side of a household style freestanding box fan, and no air will flow through.
Likewise brakes, whether drum or disc, have splash shields blocking the inner side. So if the wheel isn't open, there's no cooling airflow.
Debate the idea all you like, but notice that even in Nascar, where there's virtually no braking, they still don't use discs over the wheel faces. It's been tried, the results looked good in the wind tunnel, but on track testing was what killed the idea. By the way, your aero efforts miss even the brake cooling ducts that Nascar still uses in some races. Those would add drag, and most people do them wrong at either end, or both ends.
Choose a flat face wheel like my S-10 in my Newb Intro thread titled Sad about good MPG. Those help MPG compared to dished wheels, but still help brake cooling.
All y'all's reasoning and book learning means nothing in reality, until you've tried it. Or someone else has. Part of what makes humans human is the ability to learn from the mistakes of others.
I understand liking trying things for yourself, but when other lives are at stake, do you really have any right?
My brake fade happened as safely as possible short of renting a closed venue.
Old 05-18-2015, 08:41 PM   #18 (permalink)
Stream - '16 Volkswagen Jetta
90 day: 33.7 mpg (US)
What would be the difference, aerodynamically as well as the brake overheating issue, between moon covers and rims like these?
Old 05-18-2015, 09:15 PM   #19 (permalink)
You honestly think they don't use brakes in NASCAR.
regards
mech
Old 05-18-2015, 09:41 PM   #20 (permalink)
bikeprof's Avatar
Thanks for the VID, Old Mechanic!
As racer, mechanic and almost professional spectator(professional to some races :-) ), glowing brakes is a sign of proper set-up and proper usage of equipment as it should be...
Glowing brake rotors is a beauty that most spectators do not absorb as they do not see that because of the distant(distance) bleachers here in the USA. In other localities/countries, spectators "ARE on top" of the vehicles which is dangerous BUT VERY THRILLING :-))))
Rallying is a place where rotors that change color(s), like chameleons, can be found and that is something to observe!
