Old 03-08-2011, 03:41 AM   #61 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
The serving tray had long term durability issues. This is what happens when you leave black polystyrene lying in the sun for a month or two :
So I moved to the traditional pizza pan :
However, this is an aluminum pizza pan that WILL NEVER RUST.
I also got the number of mounting pieces reduced from 10 to 4 :
I used furniture feet because they grab onto the faux lug nut and will never come off. Also notice that the furniture feet have their tops sanded off. This makes the disk more flush to the wheel.
I made a square out of balsa-wood to find the center (different pizza pan shown) :
This worked fine for me, but there are better ways to do it in this thread :
http://ecomodder.com/forum/showthrea...pan-15993.html
This has been working since July 2010.
The only real defect in the design is the gap between the pan and the wheel :
This is because I ordered the pizza pan from a kitchen supply e-store, so I had to rely on their stated measurements. Still, I could claim that this "feature" allows for some brake ventilation.
CarloSW2
American Solar Energy Society
The Following 2 Users Say Thank You to cfg83 For This Useful Post:
aerohead (03-08-2011), Piwoslaw (04-18-2011)
Old 03-08-2011, 06:22 AM   #62 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Now paint them white, like those moonies you've always wanted!
Old 03-08-2011, 10:43 PM   #63 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Christ -
The thought has crossed my mind. But then I ran over it. If the thought survives my parietal lobe, it may yet happen.
CarloSW2
Old 02-20-2012, 05:52 AM   #64 (permalink)
Thanks for the info, I will be trying a similar design shortly. I just have to complete a few projects prior.
Old 02-20-2012, 01:08 PM   #65 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Sentraguy -
Cool. If you go with my mounting solution then you need to have bolts with "external" wheel cover mounting threads on them like my car has :
More Information for DORMAN 611109
There are tons of plastic bolt caps at Pep Boys and I assume other car parts stores. Here is a side view based on the threaded lug nut :
CarloSW2
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Alloy wheels + Metallic Tape = Aero Racing Disk cfg83 Aerodynamics 20 06-09-2010 03:23 AM
How many of us here come from a racing backround? blownb310 The Lounge 19 08-22-2009 09:20 AM
"Drag" Racing... Christ Aerodynamics 25 06-22-2009 09:44 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
