Old 07-28-2010, 06:13 PM   #41 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
OK. Numbahs.
First tankful: 548.8 miles 19.293 gallons 28.44 MPG
Second tankful: 510.6 miles 18.272 gallons 27.91 MPG
Overall: 28.2 MPG
This is over my usual circuit (one-third each urban/suburban, two-lane state roads, Interstate). Flat terrain Hot & humid (low air density)
Urban/suburban - run along with traffic
Two lanes - 60 MPH = 1125 RPM
Interstate - 70 MPH = 1310 RPM
At all fillups I eye-droppered in the last drop she'd take.
My speedo is perfectly adjusted for relatively new 235-85x16E tires @ 100 psi
I baselined (no GV) at 26.4 MPG. Base MPG down because I cut down the air dam & removed the side skirts. Even I could not stand the things.
The difference in the tanks (about a half-MPG) may be an answer to the old question about windows down- no A/C vs windows up with A/C. First was run driver's side window down and very little A/C. Second tank was windows up and A/C on recirc.
On both tanks, I was on my hypermiling game.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
DieselFan (09-01-2011)
Old 07-30-2010, 08:33 PM   #42 (permalink)
90 day: 19.36 mpg (US)
You ought to be able to hear us from waaay down here, yeehaw!
As before, hope you'll run some video/audio some day. What kind of man press/pyro temps on a run like that?
Old 07-30-2010, 09:18 PM   #43 (permalink)
Big Dave's Avatar
At 60 MPH in seventh, 500 degrees EGT Zero boost
At 70 MPH on seventh, 575 degrees EGT 1-3 psi boost
4" Slam
Old 08-20-2010, 07:51 PM   #44 (permalink)
Big Dave's Avatar
Seventh Gear
OK. The GV gained me 1.5 MPG over baseline, but I'm greedy.
I noticed my EGTs were up, so I thought maybe I've gone past the optimum.
So I experimented by putting my 225-75x16s on the drive axle and the 235-85x16s on the front.
EGTs went down but so did MPG: 26.5 MPG.
Rats!
Engine speeds.
@60 MPH - 1200 RPM
@70 MPH - 1400 RPM.
Yes, I corrected my odo by 7% which is the difference in tire OD.
OK, unless this next tankful shows a huge improvement (telling meI have experimental error) I'll swap 'em back.
That's why you experiment: to separate truth from BS.
4" Slam
Old 08-20-2010, 08:07 PM   #45 (permalink)
Big Dave's Avatar
slowmover:
A 4BT3.9 and a T-56 in a F-150 should give outstanding results. They are much lighter than Super Duties. If it were a long bed with a aeroshell, even better. I've been thinking about a 4x4 Expedition with a 4BT and a T-56 for a winter vehicle.
comptiger:
You are right. T-56s can be adapted to transfer cases.
nubbzcummins:
With smaller (like 235-85x16) tires and 3.31 gears you could get awesome MPG. Those big-diameter tires exact a huge price in rotational moment of inertia. You have four gynormous "flywheels" to pour energy into everytime you accelerate away from a light. You have to accelerate those "flywheels" rotationally before you accelerate the truck laterally.
4" Slam
Old 08-22-2010, 05:57 PM   #46 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
With regards to the EGT it could help to go one step colder and or adjust the gap. The gap might not be able to be made much bigger under boost before it blows the spark out.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 08-22-2010, 06:11 PM   #47 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Phantom - He's working with a diesel. No spark plugs.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 08-23-2010, 09:41 AM   #48 (permalink)
Phantom's Avatar
Oops I was thinking he had the Triton V10 but I guess he would be running at a lower MPG if so.
Old 09-01-2011, 02:13 PM   #49 (permalink)
Diesel Fan
Big Dave,
Does that mean that you are getting only a 6.8% fuel efficiency gain with the overdrive Gear Vendor?
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 14 03-05-2020 06:20 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Coasting in neutral or with clutch down? falfa Hypermiling / EcoDriver's Ed 83 03-12-2011 09:56 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
