Old 06-01-2022, 12:03 PM   #31 (permalink)
Not to be rude or political, but why are seemingly so many people over there batsh*t insane?
I'm hard pressed for an explanation that isn't rude or political.
The strategy used by the [corporate] British East India company 180 years ago with Opium is now being used with Fentanyl. The Dutch and British East India Companies were the first corporations, born bloody and rapacious. Now there are corporate entities indistinguishable from national governments,
Furry mammals don't stand a chance.
Ecky (06-01-2022)
Old 06-02-2022, 12:44 AM   #32 (permalink)
You can find either exceptionally good people even in places where you'd be supposed to think of the locals as a bunch of SOBs, just like you may go to a place where people are often seen as cool and end up with a bad impression of someone. But nowadays there is basically nowhere you can go and not expect to find at least someone who is effectively insane...
The Following 2 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
Ecky (06-02-2022), Piwoslaw (06-02-2022)
Old 06-03-2022, 01:34 AM   #33 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Isn't driving on drugs still illegal?
Doesn't the police do anything about that?
Either way, for such short trips I don't usualy get the car out unless there is a good reason for me to do so.
Portland is the biggest city with the “ defund the police “ and “ ACAB” movement. Cops don’t do anything here
Old 06-03-2022, 02:31 AM   #34 (permalink)
https://en.wikipedia.org › wiki › Portland,_Oregon
Portland, Oregon - Wikipedia
Approximately 2.5 million people live in the Portland metropolitan statistical area (MSA), making it the 25th most populous in the United States. Its combined statistical area (CSA) ranks 19th-largest with a population of around 3.2 million. Approximately 47% of Oregon's population resides within the Portland metropolitan area. [a]
It's half the State, but barely squeaks into the top twenty. They don't do anything anywhere there's a corrupt DA.
Autobahnschleicher -- This country gets a lot of bad press.
worldpopulationreview.com › country-rankings › mass-shootings-by-country
Mass Shootings by Country 2022 - worldpopulationreview.com
Norway led the world with 1.88 deaths per million, followed by Serbia, France, and Macedonia. Where did the U.S. rank? 11th place. Average (Mean) Annual Death Rate per Million People from Mass Public Shootings (U.S., Canada, and Europe, 2009-2015): Norway — 1.888 Serbia — 0.381 France — 0.347 Macedonia — 0.337 Albania — 0.206 Slovakia — 0.185
You have to discount the false flags, like the one just entrapped in El Paso. There's an ongoing push to take the teeth out of the Constitution. See what's happened to Scotland Australia and New Zealand?
Meanwhile, $178,000 Javelins are reselling for $30,000 in Europe.
Old 06-06-2022, 02:29 AM   #35 (permalink)
Most of the cop-bashing "influencers" are either thugs or can hire some private security to deal with the actual thugs, and eventually the private security will be better equipped than the local police, having access to better guns for instance. At least in Brazil I see it.
Old 06-07-2022, 11:58 PM   #36 (permalink)
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
More stuff besides insulation
So everyone knows that short trips with the engine cold give you horrible mpgs...
Heck in my ioniq today, a 5 mile short trip to get groceries and back with ''hypermiling'' netted me 29mpg. and its a HYBRID! obviously this was because the engine was cold and none of the fluids or parts were warmed up and at the best operating temp...
IS THERE A WAY to speed up this warming up cycle or get better gas mileage for shorter trips? would a winter heat block still help the engine warm up during hot summer months? does parking in the sun help the engine warm up faster? what other things or '' hacks'' can someone do to get better short trip driving fuel economy?
Hey again Phase!
So I see that warming your car quickly *has* been on your mind already! The insulation mentioned in the other thread is one route and a good one for short trips. It definitely reduces warmup times and improves FE, but for a 5 minute trip it would be maybe a +10%, or +3 mpg in your example. Worthwhile but not spectacular.
Another route is using the Toyota Prius trick. They take the hot coolant fluid and shunt it to a thermos when the car shuts off. Then they put it back into the coolant reservoir when you start up again. This only helps between multiple quick trips, i.e. the car doesn't warm up faster, it "loses heat slower", so to speak.
Engine block warmers, the glowplugs mentioned earlier, etc. will all work. They will give you a better mpg reading on your dash, but won't necessarily be more efficient. Meaning, you still need to spend energy to power the heaters, and (if factored into the mpg equation) is still crap net fuel economy. It's just consuming two different types: gas and electricity. To truly get more efficiency one would want to harness some natural or ambient resource for "free".
If we want the coolant to always be at operating temperature near start, then a crazy but workable solution is to use the solar oven effect. Trap a dark fluid under a clear surface and it will raise temperature quickly. Then circulate it with a heat exchanger to your coolant fluid. Some simple electronics could ensure the right temperature, and making it solar powered ensures it only comes on when the sun is out.
The main potential drawback is thermal expansion issues between the engine and coolant. Meaning, if the coolant is too hot and the engine is too cold, they might be out of spec relative to each other on startup. So it might make sense to run the "heater fluid" through the oil and across the engine as well, to try to warm up everything "evenly". The best solution here would be to find a way to use the actual coolant pump while the car is off. That may not be possible with some engines; some use the stroke cycle itself to circulate fluids. Fortunately, every hybrid I've ever seen has a separate coolant pump, because they want fine control for efficiency reasons.
Alternatively, you could use a fluidless solution, go full solar, and use something iike the Glowplug heaters mentioned earlier. Basically harvest sun for electricity to directly convert into heat. That has possibilities if you ever plan on using the electricity for anything else, whereas the fluid solution is effectively a secondary radiator.
Huh. This could actually have real applicability. If we were to view this purely as a heating problem, then the most efficient solution is to use a heat pump. So you'd use the solar power to extract heat from the heating fluid and force it into the relevant components. That not only gains the COP factor for efficiency, it means the solution would work to much lower temperatures than the solar solution alone. The heat pump could also have dual use to heat the cabin, which is much needed in cold climes.
Cheers.
Champrius 4.0 is finished and up
FOR SALE.
Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
Stats from Champrius v3.2:
