Old 01-07-2011, 06:26 PM   #1 (permalink)
Adolf - '01 Volkswagen Jetta TDi GLS
90 day: 45.84 mpg (US)
Weird ScanGauge issue
I got a new scangauge and installed it yesterday, set it all up, saved som x gauges, yadda yadda.
Today I filled up, and did the first fill up procedure. Since then, every time I start now the car info is reset to default. But the x gauges are still stored. Not sure what the issue is, anyone have this issue? Right now it is worthless to me, so any help is appreciated.
Car is a 2001 Jetta TDi. And like I said, untill I did the first fill up procedure, it worked like a charm!
Old 01-08-2011, 01:01 PM   #2 (permalink)
By car info do you mean the engine size and that its a diesel? Honestly, I'd contact linear logic. Their customer support is quite helpful.
Old 01-08-2011, 01:50 PM   #3 (permalink)
Yes, engine size, diesel a, and tank size, tried to email linear logic, still no reply
Old 01-08-2011, 10:35 PM   #4 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Mine does that occasionally. I had the unit replaced 2 ties. I suspect it is a VAG ecu issue in my case. I'd file an RMA with linear logic if I were you.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 01-08-2011, 11:14 PM   #5 (permalink)
Well I unplugged the unit, and it's working fine again, so if it happens next fillup then I will be sending it back.
