Old 04-25-2009, 10:00 PM   #1 (permalink)
Ernie Rogers
Mustang HP2g engine efficiency
Hello, folks,
I know some out there would like to know just how efficient that engine is in the Mustang HP2g. I have the answer.
I used the published data for the car, and added the following information needed to determine engine efficiency--
Wheel rolling resistance coefficient..........0.006
Air density........................................... 1.20 kg/cu.m.
Drive train efficiency, shaft-to-wheels.......85%
Okay, then I calculated the engine efficiency, assuming the numbers are for gasoline, not E85 (giving the car owners the benefit of the doubt). I also did the calculations ignoring wind. Here is the engine brake efficiency range:
104% min to about 112% max.
Based on numbers in their fuel economy log.
I conclude that these folks should receive a prize for the first internal combustion engine to achieve over-unity output.
I admit I may have overlooked some important detail, and in that case I am sure somebody will come forward with that information.
Ernie Rogers
Old 04-25-2009, 10:19 PM   #2 (permalink)
LOL!
How about a Linc-Volt analysis?
Old 04-26-2009, 10:13 PM   #3 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
They're running BS95 or whatever, so not counting whatever proportion of the energy is O.K.
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 02:32 AM
Heat engine block for efficiency? bennelson EcoModding Central 43 08-12-2008 09:45 PM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 07:06 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
