Kansas City, Mo. Smack dab in the middle USA... I've talked to a forum lurker in particular at my work Overland Park, Ks, as well as another member sighted me in the Independence area a while back.. I have also spotted a 80/90's ford festiva/fiesta that looks a bit modded out a couple times down Metcalf in OPKs. As well as a (local/local route) Green color+Vinyls Semi rig, Sporting AirTabs, pulling an AirTabs(ad) trailor through downtown on a consistant basis...
I'm sure i may have given too much info, Respecting privacy of those individual(s) so feel free to edit if needed or send me a pm to edit info... It just seems that there are a few here, but only on a lurking basis -.-
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
