Old 07-16-2009, 07:05 AM   #1 (permalink)
toad - '84 Toyota Landcruiser FJ60 G
90 day: 9.84 mpg (US)
Solar Panel
All,
I bought a cheap small solar panel to keep my battery topped up when I don't drive my landcruiser for a while.
I'm in the process of testing it at the moment on an old motorcycle battery so it hasn't been installed as yet.
Someone told me that solar panels draw current from batterys in the dark.
Does anyone know if this is the case or not?
Old 07-16-2009, 08:13 AM   #2 (permalink)
You need to install a blocking Diode between solar panel and charger. That will insure that no current can flow back to the panel. Some solar battery chargers have the blocking diodes already build in.
Best, Bernd
Old 07-17-2009, 06:52 AM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
if it was sold for charging batteries and has either a plug or a juncion box, then you most likely already have a diode in there, if it's just a panel... then it's just a panel.
Solar panel EV charging (ForkenSwift): can anyone help set up a 555/relay circuit? MetroMPG Fossil Fuel Free 21 04-18-2009 02:40 AM
Shorted out my solar PV panel - half voltage now. Help diagnosing? MetroMPG Saving@Home 3 04-12-2009 02:43 PM
xB Solar panel roof trikkonceptz EcoModding Central 10 02-28-2009 04:27 PM
Solar cell panel on the roof..?. Xringer EcoModding Central 5 09-07-2008 02:51 AM
