Old 12-30-2008, 01:18 PM   #11 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Ive never tried the sucker. Ive used the braid and it works really well. I work with a guy who used to solder for the military and he said the braid is the way to go.
Winter daily driver, parked most days right now
Summer daily driver
Old 12-30-2008, 01:38 PM   #12 (permalink)
01 Insight - '01 Honda Insight DX
90 day: 67.82 mpg (US)
I'll give my vote to the braid as well, I have used both and prefer the braid.
The sucker can be nice to take up a big ugly solder joint and then finish with some of the braided copper so you aren't using it all up.
Old 12-30-2008, 03:45 PM   #13 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Agreed. I actually have an anodized aluminum solder sucker kind of like a spring-loaded hypodermic needle. It's great for big blobs, but if you just want to clean up a single tiny joint, it's MUCH easier with solder-wick. There's a lot more room for controlled removal with wick.
Now, the big "desoldering iron" type removal tool that you are speaking of may have better control than my spring-load sucker, but the wick is still best for fine removal.
Old 12-30-2008, 06:32 PM   #14 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Fat nasty mess - sucker
But - the sucker will NEVER get all the solder.. you'll leave a mess... which is cool if you're not working on expensive circuitry with 3mil circuit lines and 5mil lands...
If you're doing anything that needs to look good for functional purposes, most definitely use the wicking... the baster will own you.
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 05:01 PM
Question about EOC with an Auto... :confused: LastBoyScout Hypermiling / EcoDriver's Ed 20 08-30-2008 07:28 PM
Prius Question Matt Herring EcoModding Central 13 07-24-2008 04:07 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 05:58 PM
newb intro and question about civic hb vx reformed Introductions 9 01-30-2008 12:28 AM
