Solving the blind spot problem
Hi,
I've been unhappy with the blind spots and never really felt the OEM mirrors were doing a through job. But in another thread at PriusChat, some folks suggested after-market, convex mirrors. I picked up a pair of 2"x1" convex mirrors, $2/each, at the local Autozone and started this experiment: http://hiwaay.net/~bzwilson/prius/pri_mirror_010.jpg This is the rear view mirror of our 2003, NHW11 Prius. Driving home, it worked perfectly and in a few minutes, I'll try some night driving. Barring some problem at night, this is working well. I'm now seeing cars in the blind spots, just behind the rear passenger doors, on both sides of the car. Not visible because the cell phone is closer than my normal eye position, the two convex mirrors overlap in the center. Also, these mirrors fit in the same area that the rear passenger head rests normally block the rear view. For less than $5, I finally feel comfortable that the blind spots are covered. I'm seeing vehicles that otherwise are not seen in the OEM mirrors. FYI, these particular, convex mirrors are "Pilot" MI-003 bought at Autozone. I have no financial interest in Pilot or Autozone. Bob Wilson |
Get the inside and drivers side mirrors from a European (mainland) market car. These cars have convex mirrors from the factory with no blind spots.
bwilson4web -
This is my current state of overkill : Quote:
CarloSW2 |
It's possible to adjust your outside mirrors to eliminate blind spots to the sides of the car. You set your outside mirrors to having a very minimal overlap with the rearview. The passing vehicles go rearview mirror -> outside mirror -> peripheral vision when you're looking straight ahead.
Don't know if that's possible on a Prius. Works well on my car. |
CarloSW2, I was considering a mirror like yours, but do you find the 17" rearview mirror obstructs useful portions of the windshield?
RobertSmalls -
CarloSW2 |
Doesn't anyone check over their shoulder anymore?
Hell, I don't even use the mirrors on Cara most of the time, because I'm not entirely concerned with what's behind me unless I'm slowing down, and I'm not entirely concerned with what's beside me unless I'm changing lanes... And even then, I check over my shoulder unless physically unable, like in box trucks and large vehicles which aren't equipped for passenger travel. My OE mirrors are set so that there is no overlap and no blind spot, as well. Method for setting mirrors: Get into driving position Lean your head to the left as far as you can while keeping your head in the straight up and down position, so that an imaginary line down the bridge of your nose would remain vertical. Adjust left mirror so that the sheet metal of the vehicle is just visible, then move the mirror until the vehicle is just out of sight in this head position. Lean head to the right, using the same method, adjust right mirror (have someone else adjust it if it's a manual mirror and you can't adjust it from your driving position). Adjust rearview mirror so that you can see equal parts of the rear interior on all sides of the mirror. If you use this method correctly, you should have no (or minimal) blind spots, and you won't need to move your head to use your mirrors properly. You just don't need to look at the corner of your car while you're driving, although many people apparently assume that their ass-end is going somewhere the front hasn't already been. |
The convex mirrors provide 'the whole car' and work great with motorcyclists and Smart cars. This morning on the way into work, there was a Mini Cooper that was completely masked by the "Method for setting mirrors" but it was clearly visible in the convex mirror. I'll post photos from my cell phone this evening. One other aspect is the convex mirrors also show parts of my car, the door posts, which gives context or sense of exact location that the "Method for setting mirrors" does not provide. Those mirrors just point out into space with no reference relative to your own vehicle. Regardless, this story led to this most recent effort: I Crashed into a Scary Biker Dude | momlogic.com Quote:
Bob Wilson |
Hm. I haven't had a problem with losing cars as they pass (I'm not usually the one doing the passing...) and I can see motorcycles on the highway that ride in the right-most section of the left lane while they're on my corners. I've used that method on every car I've driven, and I've noticed that only on those with extremely long rear-ends (box trucks and flat beds) that there are still blind spots, but on the average <20 foot length commuter vehicle (misnomer, I know), there are none.
However I still end up turning my head most of the time. Because depending on the weather I might have 1 shirt on or 4 shirts on, or boots or not, changes the position I am in relation to the mirrors. And the only way to really set them properly is to be on a straight level piece of highway, which I don't get unless I am going downstate. |
