Old 03-05-2014, 09:00 PM   #1 (permalink)
...beats walking...
Some interesting DI engine news
GM's info on "delayed start" with DI engines (due to temperature):
Extended Cold Crank with Direct Injected Engines
Old 03-05-2014, 09:07 PM   #2 (permalink)
^Interesting.
And "check" this out:
Tire Cold Weather Cracking
I've never heard of such nonsense! SMH
Old 03-05-2014, 11:43 PM   #3 (permalink)
Yes, tires are very sensitive to temperature. They carry the race tires in refrigerated trailers anymore to preserve the quality for races. In addition to cracking, tires turn brown when they start to age. Almost makes the use of tire shine necessary to keep them from drying out.
My mercedes 240d had a cold start procedure for extreme conditions. Pull out the cold start advance, twist the high idle knob all the way clockwise.Turn key and wait 20 second. Press accelerator to the floor and hold it and the starter for 30 seconds. If it didnt catch repeat.
They also recommended adding a few gallons of gas-o-line to the diesel tank too or use a blend of kerosene in the colder climates.
Old 03-07-2014, 09:02 AM   #4 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Driving an old diesel teaches you "just because you hear it fire, don't let go of the starter just yet"
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
The Following User Says Thank You to JasonG For This Useful Post:
Cobb (03-07-2014)
Old 03-07-2014, 09:10 AM   #5 (permalink)
PressEnter[]'s Avatar
TheEgg - '18 Volkswagen Tiguan SEL Premium
90 day: 29.55 mpg (US)
I guess they need some glow plugs
I was concerned about cold starts with my Jetta, but it seems they've pretty well solved it. My coldest start was at -17F, and it fired right up with only one glow plug cycle.
The Following User Says Thank You to PressEnter[] For This Useful Post:
Cobb (03-07-2014)
Old 03-07-2014, 09:52 AM   #6 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Their starters are made to crank for a long time, though.
The Following User Says Thank You to Miller88 For This Useful Post:
Cobb (03-07-2014)
Old 03-07-2014, 10:18 AM   #7 (permalink)
Nothings more frustrating than to have oil psi, see smoke from the rear end, but the engine wont catch.
Mines was toast and needed starter fluid to start in 85 degree weather. 475 thousand miles was the end of the road for it and I had replaced the glow plugs twice.
