Old 02-22-2012, 07:30 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
draining refrigerant HELP
I have the sunfire in the shed and am getting ready to pull the motor. I need to remove the A/C system and can't get the car to a shop. I don't want to vent it and have placed a free add on craigslist for anyone who has the equipment to evacuate the system. I am not sure if there is even anything in it. My brother and I carried the car in the shed and around a corner. There is no way it is coming out right now. Any suggestions?
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 02-22-2012, 08:35 PM   #2 (permalink)
Do they ever try to recover 134a? I wouldn't give it a second thought let it go.
Old 02-22-2012, 08:45 PM   #3 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
See if you local Autozone or other parts store might be able to lend/rent the equipment to you.
Rooster: Bad boy.
Old 02-22-2012, 08:49 PM   #4 (permalink)
Versa - '12 Nissan Versa Hatchback S
90 day: 39.65 mpg (US)
R134 isn't bad. I have just let it go on several times while working on cars. I only do it with R134. If I run into the older stuff I will have it evacuated, but I don't see the need to with R134.
Old 02-22-2012, 09:09 PM   #5 (permalink)
Team Pontiac
is it dangerous to me?
will there be any residue to make things yucky and make the shed a mess?
1991 F-250:
Old 02-22-2012, 09:25 PM   #6 (permalink)
If you use your finger to push the pin to let it out it will get cold and possibly frost bit. Poke it with a screw driver and see if anything leaks out. Or just take a joint apart and watch for refrigerant leaking, it's just a gas with tiny bit of oil you probably won't see.
They sale the stuff at walmart so it can't be that dangerous or enviormentally unfriendly.
Old 02-22-2012, 09:26 PM   #7 (permalink)
Can you remove the ac compressor and leave the lines connected? Or are you eliminating the AC system?
regards
Mech
Old 02-22-2012, 09:42 PM   #8 (permalink)
TheEnemy's Avatar
R134 isn't as bad for the environment as the old stuff, but its still not good for it.
If you can have it handled properly.
Old 02-23-2012, 12:07 AM   #9 (permalink)
Team Pontiac
the system is getting removed. I have a bypass pulley on the 3800 and like how the numbers feel on my butt o meter without it.
1991 F-250:
Old 02-23-2012, 06:21 PM   #10 (permalink)
Team Pontiac
HAHA...the joke is on me. The system was already empty! Good thing I tested first before trying to load it on the flatbed and take it into town. There was a small hissy puff and that was it. Saved me at least a day and a half.
I have pulled the right axle shaft out and have stripped the motor. Tomorrow I will get the left shaft out and then it will get pulled as soon as I find a way to lift it.
I don't have the cash for a hoist, so it will probably have to be lifted by hand.
I will keep you posted.
1991 F-250:
