Make sure that the window is closed tight or just try adding some cheap foam tape for insulating. That will reduce some of the vibrations from the frame to the window and reduce air movement and help block some of the sound.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
