Old 04-19-2011, 06:46 PM   #31 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by rmay635703 View Post
In the real world you may find that its basically a wash.
I typically run much higher load tires for the harder tread compounds, higher presses, and longer life when used on lighter applications. Traction is reduced, but that's a moot point for most of us, imo.
Old 04-19-2011, 06:51 PM   #32 (permalink)
Originally Posted by Christ View Post
I've had that thought about valve springs, as well... But I've been "corrected".. Not that I believe it.
Well that is the difference between steel and rubber; deform spring steel and when it returns to original shape it does it with little internal "friction" or energy loss, while rubber behaves quite the opposite.
Old 04-19-2011, 06:57 PM   #33 (permalink)
But the spring is pushing against a rotating object, which, at speed, is probably rotating away from the spring close to the same speed that the steel spring can return to original form, not to mention the lack of force application, since the force of the spring is pushing back against the can at close to the cams center line, or with rocker type valve trains, pushing against a lever which rides near the center line of the cam. Applying linear force to a rotating object without leverage in the direction of rotation? Sore, that's a winner...
Old 04-19-2011, 06:59 PM   #34 (permalink)
Non dimensional, non linear concept here, only concerning material properties...
if we had rubber valve springs and steel tires I would expect them to behave the opposite of what they do now as far as energy losses.
Old 04-19-2011, 07:01 PM   #35 (permalink)
Material properties, I agree.
Old 04-19-2011, 11:16 PM   #36 (permalink)
Bettsy - '02 Honda Civic EX 4DR
90 day: 39.94 mpg (US)
Old Faithful - '00 Chevrolet Silverado 1500
Last 3: 21.1 mpg (US)
Wow,I never thought this thread would go on this livley and this long. I may end up getting the altima wheel and a 145 tire combo. I weighed the spacesaver for the civic and it's a bit heavy at 26 lbs. with the tire and it's just butt ugly. I suspect honda did this to shame you in to not running them any longer than necessary! The altima wheel is descent looking for a steelie and the suave honda wheel covers (HAHAHA) may even fit them.
Old 04-19-2011, 11:55 PM   #37 (permalink)
500 Mile Metro Traveler
'89 Dakota LB - blue - '89 Dodge Dakota V6 LE
90 day: 19.8 mpg (US)
'17 Fiat 124 - SunFiat - '17 Fiat 124 Spider Classica
90 day: 30.51 mpg (US)
'89 Metro - The Egg - '89 Geo Metro Base
90 day: 50.71 mpg (US)
'94 Alto - The Box - '94 Suzuki Alto Ce-L
90 day: 39.5 mpg (US)
The RX7 spare wheel and tire (4x114.3 bolt pattern, with a 40mm offset) is 21 lbs
Old 04-20-2011, 07:16 AM   #38 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by justjohn View Post
Hahah. I read it. I just don't get the part about load capacity going up by a greater percentage than tread and how that translates to lower RR.
The load carrying capacity of a tire is directly tied to the internal volume of the tire.
If we take the example of a tire with a 100% aspect ratio (because the cross section is a circle and that's easier to visualize), then the volume of the torus (the shape of a tire) is a function of its cross sectional area.
The area of a circle is pi* r-squared. If the radius is increased one unit, the the area is pi* (r+1) squared = pi* (r+1)*(r+1) = pi*(r squared + 2r +1).
It's that 2r term causes the area to go up faster than the increase in r.
Tires are oval in cross section, but that only makes the formula more complex. It doesn't change the fact that the width is squared to get the volume.
Old 04-20-2011, 10:11 AM   #39 (permalink)
Black Beauty - '13 Hyundai Elantra
Well I think the volume formula would actually have a pi^3 in it, but okay I get that part then.
What I still don't completely get is how increased load capacity... wait a second. Unless you're saying that this means there is actually less tire in contact with the road. Which seems counter-intuitive to me, but would definitely give a reason for decreased RR.
Old 04-20-2011, 10:19 AM   #40 (permalink)
Tire Geek
CapriRacer's Avatar
.......... wait a second. Unless you're saying that this means there is actually less tire in contact with the road........
Yes, tires with different load capacities deflect differently at the same load, with the tire with the larger capacity deflecting less.
