Old 10-22-2011, 07:19 PM   #1 (permalink)
Reloadwin's Avatar
Silver Prius - '08 Toyota Prius
90 day: 46.37 mpg (US)
97 Honda CRV Aero Mods
Hello All, I started reading and fallowed what others have done on this site. Let me know any ideas or suggestions. This is only a temporary setup, next I will use aluminum sheets for a better custom design. This setup I used coroplast from a local sign store I found. $20 for one 4x8 sheet. Looks like it has already saved me from a possible flat tire.
Old 10-23-2011, 10:24 PM   #2 (permalink)
Evil Genius
LPG FTW - '96 VW Cabrio
The Green Bimmer - '95 BMW 525i
The White Bimmer - '94 BMW 530i
haha luck be with you lol. it actually looks pretty clean for a coroplast install. maybe a splitter could be installed to further strengthen the plastic and keep some more air out from under the car.
Old 10-24-2011, 02:26 AM   #3 (permalink)
'10 Kia Forte EX 2.0 - '10 Kia Forte EX
90 day: 37.29 mpg (US)
That's a pretty big increase in frontal area. It might be too much.
Old 10-24-2011, 07:39 AM   #4 (permalink)
OurInsight - '06 Honda Insight
Looks good. I assume that in St. Louis this time of year that you are getting enough cooling, and I see that the cooling slot is adjustable - good.
I second the idea of a small splitter at the bottom. You can find some lighweight aluminum angle extrusions at Lowes or Home Depot that can be bent into gentle bends and pop rivited into space
Have you don an A-B-A test yet?
Old 10-24-2011, 06:34 PM   #5 (permalink)
airdam
The airdam is a good move.I would recommend,that if you had more coroplast,that you shingle a bit more behind the trailing edges,wrap it tight against the sides,and bring it as far rearward as you can without scrubbing on the tires.( current NASCAR noses would offer a fine example to follow)
I'm concerned that as she sits,the lower sides are directing air outward instead of back,and this will aggravate the flow along the sides.
My pickup responded very favorably to this kind of setup,I think you'll be well rewarded at the pump.
Reloadwin (10-24-2011)
Old 10-24-2011, 08:51 PM   #6 (permalink)
Reloadwin's Avatar
Thank you for your input, could you please take a picture of your setup?
Old 10-25-2011, 05:57 PM   #7 (permalink)
setuo
Reloadwin,go to the 'Full-boat-tail trailer with gap-fillers for Toyota T-100 pickup' thread near the bottom of the first page here at the aero forum.
Go to page 16,and down to #154 permalink for a pic of the trucks nose.'I'd do a link,but I don't know how yet.Sorry!
Reloadwin (10-25-2011)
