Old 11-28-2021, 03:06 PM   #1 (permalink)
Spherical Solar
I've always struggled with the problem of putting solar panels on geodesic domes. Only hexagonal cells offered any hope. Comes now Spherical Solar Cells:
The paper is at ieeexplore.ieee.org/document/9300766 if you can log in.
Abstract:
In order to realize a high power conversion efficiency, a solar cell should effectively utilize most of the incoming photons. Here, we demonstrate a spherical shaped solar cell that is capable of capturing direct, diffuse and background reflected light without the need for a mechanical sun-tracking tool. The spherical cell is based on monocrystalline silicon with an efficiency of 19% ad is developed using a corrugation technique to achieve flexibility in otherwise rigid silicon. The obtained spherical cell is large scale with a diameter of around 4 cm. Theoretical calculations in addition to experimental results confirm the merits of the spherical solar cell which shows an increase in instantaneous power output by 14.8% and 39.7% with respect to a traditional flat cell with the same ground area when sand and white paper are used as reflective background materials, respectively. Finally, the spherical shaped cell shows advantages in terms of lower dust accumulation rate due to its downward orientation.
Of course this just trade one design problem for another: How to integrate little round balls with a big one. I imagine the solution would be a large solar sphere at the zenith, with panels that open like a flowers petals.
But the technique of corrugating the cells so it will fold could produce convex panels, as well.
Here's the solar beads: www.sphelarpower.com/
You can't be wise and in love at the same time. -- Bob Dylan
aerohead (11-30-2021)
Old 12-06-2021, 09:25 PM   #2 (permalink)
I somehow doubt that putting 4cm spheres all over a car will help its aerodynamic characteristics...
Old 12-07-2021, 12:19 AM   #3 (permalink)
He covers two type of solar solutions. The other can produce arbitrary compound curves.
This is General Efficiency. Not just cars here.
