Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 04-21-2018, 02:15 AM   #1 (permalink)
Sprouts and Electric Gliders
It would be pretty rad to have a solar powered electric glider that also had atmospheric water harvesting, I have to think about this more because, I realized that while harvesting, we are increasing mass AND thermal energy. If there is a way to regenerate thermal energy from the additional thermal mass using only solar power I don't know, BUT I have thought about making some parallel series hybrids. There would be a larger thermal mass. The series are gas electric, but I make them parallel for the purposes of regenerating thermal energy. It would be awesome to make it automatically rinse beans at the same time.
I think we can get really good regeneration for few cell charge cycles, but we are talking about a glider. The whole mode of transportation is hypermilling.
Say there are three 1hp motors at 2lbs each. 3 evacuated tubes at .4lbs each. A gallon of water weighs 8lbs. A gallon of gas weighs 8lbs at 50 degrees f. I like to precool the gas and the evacuated tubes. I want to put little electric block heaters on the little engines. So, everything is in an ice chest. AND!!! 160L of air weighs .4lbs. 160L is a 20L tank at 120psi. Just for fun.
Old 04-21-2018, 03:20 AM   #2 (permalink)
Hase Pino
https://www.google.com/url?sa=t&sour...6WeCOo6hy0Z2NF
The Hase Pino is a tandem/cargo bike geometry. Since i will have a clean and dirty thermal mass. I think i will make two solar panels. One rides on the front and one rides on a trailer. The dirty one only runs when i travel. This way i get some more surface area.
Old 04-21-2018, 03:50 AM   #3 (permalink)
I decided to use two 1hp motors and one air motor for left over boost. I am not recycling exhaust now, but i will run them lean. The block heaters will make that work right?
Old 04-21-2018, 03:51 AM   #4 (permalink)
And i am thinking of putting the air tank in back of the standover rider
Old 04-23-2018, 02:34 AM   #5 (permalink)
You will be boiling water to create pressurized fluid or gas for power?
Old 04-24-2018, 03:08 AM   #6 (permalink)
...I have to think about this more...
I think you got that right.
It would be pretty rad to have a solar powered electric glider that also had atmospheric water harvesting, ..., I realized that while harvesting, we are increasing mass AND thermal energy.
Yes but why the bicycle frame? I suggest steam for lift: The Flying Kettle Project - balloons and airships filled with steam!
