Old 05-05-2011, 06:12 AM   #41 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by donee View Post
I am running a .035" thick tubulator behind the peak height right now.
On gliders, the turbulators are placed forward of the thickest part of the wing as they want the turbulized air to make the bend.
Aft of the peak height, you'd already have separation and the damage is already done, right ?
Old 05-05-2011, 06:38 AM   #42 (permalink)
- - '10 Toyota Prius III w/Navi
No. Turbulators are placed in front of the seperation in flow, but this is usually just behind the maximum chord (height in a car) of the wing. On a wing the flow seperation occurs just after the maximum chord.
Documenting NHW11 Prius rear window flow separation; testing AirTab vortex generators bwilson4web Aerodynamics 19 11-05-2010 06:25 PM
Gen III 2010 Prius Matt Herring Hybrids 3 08-30-2010 03:04 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Prius fatal accident rate bwilson4web Hybrids 22 02-05-2010 11:23 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
