Old 09-29-2011, 11:35 AM   #1 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Failed emissions -92 MX-3 GS
A week ago poor Princess failed emission with the following results(limit in parenthesis):
  • CO 2.1(0.5)%
  • CO2500 0.6(0.3)%
  • HC 235(100)ppm
  • Lambda 0.98(0.97-1.03) (Passed, but listed for reference)
A while back the ignition module failed on me, and while diagnosing there was a lot of starting. So i suspect that the oil is flooded gas soaked, i'll be changing that soon, and also checking ignition timing, since it may have shifted when i disassembled the distributor.
There is another symptom also: When hot she hesitates on low revs, but runs fine otherwise. I hope it's nothing more expensive like lambda probes or MAF sensor.
I'd also like to know if anyone has had problems from EOC:ing too much, like 70% of their distance.
Old 09-29-2011, 02:29 PM   #2 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
How old is your MAF sensor? It might need to be replaced also did you have the spark plugs replaced? Try cleaning the MAF remove the MAF and Clean it with electronics cleaning spray let completely dry before installing.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
The Following User Says Thank You to Phantom For This Useful Post:
jakobnev (09-29-2011)
Old 09-29-2011, 03:56 PM   #3 (permalink)
Eco-ventor
jakobnev's Avatar
House of Tudor
Team Mazda
Plug-in Hybrids
The spark plugs are new, the MAF sensor otoh i think is as old as the car. I'll look at it tomorrow, thanks for the tip!
