Old 08-10-2013, 09:45 PM   #51 (permalink)
Only if the gun turret is facing aft
Old 08-10-2013, 09:48 PM   #52 (permalink)
Cd
Ultimate Fail
Cd's Avatar
In other words, is that Kamm-back helping even a teeeny bit, since the flow from the windshield is a total mess !
Old 08-11-2013, 12:42 AM   #53 (permalink)
Heh- the idjits put the roof on sideways.
Old 08-12-2013, 07:01 PM   #54 (permalink)
bubble front
Yeah, but to answer the question, would an H1 and H3 with a bubble front end best .24 and .12?
It's a really good question and I'm gonna go back to 1922 to begin to answer it.
*Jaray's 'bubble-front' half-airship',
'pumpkin seed' car was measured at Cd 0.13 in the Zeppelin Work's wind tunnel by Klemperer,based on a streamline body of Cd 0.045.
*In 1933,Walter Lay did his model research,and using 'Hucho's' optimization of leading edges produced Cd 0.12 without the 'bubble nose,'on a longer 'car.'
*About 1938,Koenig-Fachsenfeld and Kamm duplicated Lay's model and measured an identical Cd 0.12.
*In the 1970s,when Hucho was at Volkswagen,they found that they could achieve essentially as low a drag as the 'ideal' nose on the Golf/Rabbit just by softening the leading edges of the car,any further rounding showed no drag reduction.
*The same thing happened with the Vanagon.A 'BUG' nose as on the Schl'o'r pill-bug car would show no drag reduction over what went into production.
All of this is at zero-yaw.
Later in Hucho's book,back in the chapter on commercial vehicles,we find that the 'bubble-nose' demonstrates the lowest drag in crosswind conditions,which is statistically where we do most of our driving.
I believe that GM/VOLVO published that we could expect the equivalent of a 7-8 mph crosswind component on any given day of driving.
To your question:
*The H-1 with bubble-nose would see closer to Cd 0.12 (of course it would need a belly pan and close up some of the major gaps 'n such)at zero-yaw.
*The H-3 with bubble-nose would see no appreciable drag reduction at zero- yaw.The wheels themselves would have to be better integrated into the body to go below 0.12,as we see with Honda's Dream solar race car series,NUNA,and this year's Cambridge University Eco-Racer (CUER) for examples.
Old 08-13-2013, 02:03 AM   #55 (permalink)
"If you don't have attached flow at the front, will improving the back matter?"
Overheard on the Salt*
"It isn't the hole you punch in the air, it's the hole you leave in the air"
*actually at a table outside a Mexican restaraunt in Wendover.
Old 08-16-2013, 02:54 PM   #56 (permalink)
Project EconoPolo - '04 Volkswagen Polo Twist TDi
90 day: 48.23 mpg (US)
Confession - I haven't read all of this thread, but I'm computing the OP request now.
Viio
Amateur SolidWorks Flow Simulator
Link to my Project EconoPolo (aeromodding a VW)
Old 08-16-2013, 03:06 PM   #57 (permalink)
As requested, 10 foot long tear drops, 3 dimensional (round). Wind speed is 50 mph.
Let me know if you'd like any more.
By the way - thanks, my wife now thinks I'm making sex toys on the computer.
Viio
The Following 5 Users Say Thank You to viio For This Useful Post:
aerohead (08-16-2013), BamZipPow (06-27-2014), Cd (08-16-2013), sendler (08-17-2013), Xist (06-28-2014)
Old 08-16-2013, 06:49 PM   #58 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
[QUOTE=viio;385657]10 foot long tear dropsQUOTE]
Thanks. Is there something on that screen shot which shows the total cd for each?
Old 08-17-2013, 07:41 AM   #59 (permalink)
sendler's Avatar
[QUOTE=sendler;385682]
We actually don't even need to know the cd for each since they all have the same frontal area. Nor any actual value for the drag force. Just the relative drag force between the different shapes.
Old 06-26-2014, 07:41 PM   #60 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
The top one looks similar to the CAP 21 symmetrical airfoil for aerobatic planes: CAP 21 (TraCFoil) (cap21c-il)
It uses straight lines on both surfaces from about 20% chord on back.
