EcoModder.com
-   -   Subaru legacy??? (https://ecomodder.com/forum/showthread.php/subaru-legacy-15386.html)
crawlerdan 12-05-2010 11:41 PM
Subaru legacy???
hello- im new here
i drive a 91 legacy wagon
i am always striving for as much mpgs as possible without been retarded or dangerous
heres what ive done to my 2.2 litre 4 cyl and 5spd AWD car
ive added a free flowing intake and exhaust
lifted the car 3.5 inches to allow fitment of drastically larger tires. at highway speeds the larger tires act as an overdrive, lowering my rpms at a given speed 9%. they are inflated to sidewall max
i went from a 195 70 14, to a 205 70 16
ive also installed a vacuum guage and monitor it
ive reduced weight significantly without sacraficing the utility of the car and the fact im a father of 2
if removed cross bars in the roof rack
as much as i would like to monitor using a scanguage, it is an obd1 car....i have one on my 4runner though:D
what else do the pros recomend i do with an obd1 station wagon with a lift kit? im looking to drive it cross country in the near future and want to save dough :turtle: ....hehehe a turtle
RobertSmalls 12-06-2010 07:37 AM
I think you're going to have a little trouble with that, but you could start with an mpguino, returning the car to stock ride height, adding a grille block and removing the roof rack, and getting some low rolling resistance tires. :thumbup:
crawlerdan 12-06-2010 10:22 AM
well- i noticed a significant increase in MPG with the larger tires, like i said, they act as a sort of overdrive. plus- i need the ground clearance- i live on a farm :D
what is a mpguino?
crawlerdan 12-06-2010 10:34 AM
ok- did some research and found it.
problem is- my car does not have a VSS, it is a cable and analog guage
Weather Spotter 12-06-2010 11:01 AM
Welcome to the forums!
Have you looked over this list of proven mods? It has nice user data to show MPG gains:
Car MPG Efficiency Modifications Main - EcoModder
A grill block is a good first place to start. With the car raised a belly pan is a must.
dennyt 12-06-2010 11:05 AM
I'm sure it does, I have a '94 Loyale (the predecessor to the Legacy) and I found a VSS signal. The ECU uses it.
crawlerdan 12-06-2010 11:17 AM
your loyal uses a cable for the speedo/odo as well as mine does
so where are you picking up a VSS? Thing i could think of is maybe somewhere in the ABS system, but i dont have abs, and neither do you.
i would like to see how you hooked up a mpguino if you have one though
crawlerdan 12-06-2010 11:19 AM
haha- your on USMB too. small world
dennyt 12-06-2010 11:21 AM
I'd have to look at the wiring diagram again, but there's a vehicle speed signal coming from the transmission. I tapped into it at a connector under the dash.
I don't have my MPGuino up and running yet because my (single) fuel injector is the peak-and-hold type, and the 'guino is set up for the more modern type. But the MPGuino does read speed correctly.
crawlerdan 12-06-2010 11:25 AM
the mods i have on my legacy ive done to several other subarus. this is my 21st in my name, and 88th thats passed through for whatever reason
my 92 loyal with a 3 inch lift and larger tires consistantly yeilded 43mpg
my 86 gl with a carb and lift kit, low rolling resistance tires, saw 35 avarage
